Question about M-Audio Axiom Pro 61 Advanced 61-Key USB MIDI Controller
M audio repair
The keyboard display lights up but then shuts off. What can I do? Opened it up and nothing looks burnt out.
I have a Technics PR-305 Digital Piano. I had a couple of guys come out to see if they could fix it. Only the LCD display and the front light worked. It must be the power supply.
Technics, digital piano, keyboard repairs, repair, service ...
www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keybo...
technics, technic, tecnic, digital piano repair, service, servicing, digital, electronic, ... pr200, pr250, pr270, pr3, pr300, pr303, pr305, pr307, pr350, pr370, pr40, pr5, pr50, ... It needs extremely specialised repair work which must only be carried out by .... nodisplay, LEDS don't light up (except for the one on the front of the piano ...
Dec 18, 2015 | Music
How can I repair np-11 wont sound
Hi, The reason for no sound could be many things.
Do you have power to the keyboard ( Red light, display lit up ? ) If not could be power supply or power input socket ( these fail and need repairing frequently on older models )
If you have power then check nothing stuck in headphone socket as this would stop sound.
If nothing stuck in headphones, does it work on headphones. If it does it is probably the amplifier that has stopped working.
If you can provide more specific I may be able to help further.
Dan
Oct 30, 2014 | Yamaha Music
Where would I go to get a back light for a Technics PR-305 Liquid crystal display
It could be the light, or it could be the inverter that powers the backlight. Try asking this guy: http://www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keyboard-ensemble-repairs/
Jun 09, 2014 | Universal MCU Extension 4 x 4 16-Key...
Neko lx5
Please find if your piano
is vibrating more than before
If it is not problem
THen go to nearest repairer
if it can be repaired you must repair it
And it doesnt YOU have to change It !!!!
Mar 19, 2014 | Open Labs Used Neko Lx5 Portable Keyboard...
When I play the keys too fast the whole keyboard shuts off with how can I fix the problem as I recently just began learning the piano I will find it very unfortunate to have to bring it in for repair after...
Is it possible you have the wrong power adapter? Next to the power socket on the back of the keyboard it should say what voltage and how many milliamps it needs (eg: 9v DC 500 mA). You should find a similar rating on your adapter.
If the adapter doesn't quite produce enough mA the keyboard will happily sit doing nothing but shut off when you raise its power requirements by playing a lot of notes.
Aug 01, 2011 | Casio Lk-220 Stad 61 Lighted Key Keyboard
My Orange amp recently stopped working, as in no sound
The pilot light means NOTHING other than the switch is on and unit is getting power from a receptacle.
There is an electronic failure that requires servicing and until unit is opened and analyzed we can''t help you further. Take it to a shop or a person experienced in electronic repair.
May 09, 2010 | Orange Rockerverb Rk100htc 100watt...
I have a Yamaha YPG-525. Everything is working except the LCD screen. It turns on, but doesn't display anything... I had this problem once before when I didn't use the keyboard for a while, but it ended...
I have the same problem, mine is Yamaha YPG-625. This seems to be a common problem with Yamaha keyboards. I opened the 100 screws in the back, separated the main board from the display unit which is under it if you flip the keyboard upside down, to verify if there was any loose wires, nothing of the sort.
It is so frustrating, the keyboard is working fine but it is hard to navigate because the display is not functioning. Yamaha should do a recall as this is obviously something wrong with the keyboard happenning to a lot of people
Jan 08, 2010 | Yamaha Full-Size Keyboard
I am getting the error message scn on my p120 keyboard and there is no sound from the keyboard.
Just bought a P120 from craigslist. A computer recycle company was selling it as parts for $150. They said it has the SCN error code and the keys don't play. It played the demos only.. Payed $100; took it home, opened it up & found the keyboard plug had detached from the motherboard. Plugged it in & BAM! It works just fine.
Oct 18, 2009 | Music
Roland Dp 2 Damper Pedal dont work
I'm 90% sure the pedal is shot ... It could be the switch ... Open the thing up (If your confident) and look to see if a wire has come loose ... If no wires are loose then try another working pedal with the keyboard.
If it still won't damp then there is a problem with your keyboard and I do not suggest opening up one of those ... I used to repair sockets and keys on those for a local boys school and there are full of things that can break if not opened properly,
My suggestion is getting someone in to repair the keyboard if its that ... If its the pedal then either get a new one if you don't want the old one repaired ... Or repair it yourself (pretty easy if its the wiring ... fiddly if its the switch but only attempt if your confident and have the proper tools).
Apr 23, 2009 | Roland Dp 2 Damper Pedal
Yamaha PSR-280 : AC power instead of DC power
An answer, but likely not a solution. I believe all Yamaha PSR series keyboards use the same 12 VDC adaptor, so I looked at the electrical schematic for another model I have. There seems to be no fuse on the power input. There are two components shown on the positive and negative wires off the power socket, but the symbols do not look like anything I have seen for fuses - they may be resistors. Power goes directly to a 5 VDC voltage regulator, which powers all of the solid state componenents. Too much voltage of the wrong type could have easily ruined many of the sensitive components.
Your only hope is to check the power socket area for the possibility of having fuses. My drawing shows the power socket, voltage regulator, and audio power amplifier being on one circuit board. That may not actually be the way it is in your model.
(your English is fine)
Feb 23, 2009 | Yamaha Portable Keyboard with 61...
M-Audio Axiom Pro 61 Advanced 61-Key USB MIDI Controller Logo
Top M-Audio Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a M-Audio Music Expert? Answer questions, earn points and help others
