Question about Hitachi 62VS69 62" HDTV
I have a vary dark picture except the top 6 inches of the screen. I have replaced the bulb is there a angle adjustment for this
How do you adjust the lamp. it has been replaced and i have 6 inches at the top that is back lit but the rest of the screen is so dark you better be in complete darkness to see anything
    Master:
  • Hitachi Master
  • 687 Answers
Will probably need the light engine/optic block for this unit; If you can even locate it the cost would be prohibitive on this older unit.
You can buy a new LED or LCD for less.
Posted on Jun 05, 2014
  • 1153 Answers
SOURCE: No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Posted on Sep 09, 2007
SOURCE: problem with picture it is very dark
hi,
Just a guess,under the power button, inside the the flip[ down cover is a light dimmer,you can turn this on and off,in advanced settings under video,a flash light will trigger the sensor to see if it works the dimmer,if not it could be that circuit or your power supply needs work,I hope this helps!
Posted on Oct 25, 2007
ctf1800
  • 4402 Answers
SOURCE: hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
  • 1153 Answers
SOURCE: Hitachi 57F500, Dark areas
Hitachi dark problems at ctechnicians.com
Posted on Dec 27, 2007
  • 927 Answers
SOURCE: Ultravision image dark
Good Day, tfarmer;
Since you have replaced the lamp, which is the normal cause for a dark picture. Have you checked your video settings?
The brightness level should be set at about 55 to 60%, the contrast should be set at about 90% and the video temp should be at normal or high.
If all these are set about this way, then I would think that the light engine might be going bad.
Good Luck, big IRISH.
Posted on Aug 02, 2008
Dark Band on Samsung projection TV
most likely optical engine issue----bad light engine.
Aug 27, 2012 | Samsung BP96-01073A E-Series Replacement...
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
Panasonic 51 inch rear projection--bought in 98 has dark picture
http://www.purelandsupply.com/Panasonic-Projector-Lamp.html or go here and call them @ https://www.interlight.biz/ they will answer any question and are half the price most of the time, please give me high rating
Apr 16, 2010 | Panasonic CT-27SL14 27" TV
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
TV screen is dark
If the picture is dark then I suspect a bad lamp if you just replaced it...
Nov 20, 2009 | RCA Televison & Video
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Periphery of screen changes tint
hit crt with open palm in distorted area.if changes broken shadow mask no repair except crt replacement. if not could be magnatized. needs degaussing
Dec 07, 2008 | GE 35GT690 35" TV
46 inch rear projection tv bulb replacement model number 46gw944
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Feb 05, 2008 | Televison & Video
PROJECTION TV Phillips 9P6031c103
this is what convergance looks like;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if pix is dark their is 6 adjustments knobs in the front of the tv under the screen and behind the plastic cover. the top three are the brightness bottom three is focus.
Nov 24, 2007 | Toshiba 53H71 53 in. Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
