Question about Acer AL1916W 19" LCD Monitor
WHY my accer monitor comes up shows "accer" and then goes blank power off and comes
ETLKR0D00121606AA38506
    Problem Solver:
  • 6 Answers
Hi Ali,
Sounds like the familiar leaking capacitor syndrome.
You will need to remove the back from your monitor which can be a challenge in itself.
Have a look at the power supply board which is the board that the mains cable plugs into.
You should find that some of the capacitors have a bulged appearance on the top or a gooey substance has leaked out onto the board.
Capacitors are the small metal cans on the circuit board.
These need to be replaced and if you are reasonably proficient with a soldering iron this should not prove too difficult.
Try eBay or somewhere similar to locate replacements which are not expensive. Make sure you buy capacitors which are described as low esr. If there are more capacitors of the same value on the board then it would be wise to replace them all.
You should be rewarded with a fully working monitor once again.
I have repaired many monitors with this problem and this has always been due to these leaking capacitors.
Wishing you every success Ali.
Posted on May 20, 2014
What do i do when it comes on and shows analog then goes blank ?
Are you using the analog input or another? If using another input instead, then press the 2 key. It will switch to another input as the source signal. If you still experience trouble, please contact ViewSonic technical support for assistance.
May 03, 2014 | ViewSonic VG1930WM LCD Monitor
Monitor goes blank and power light remains on and when i turn it back on, it stays on for about 3 seconds and goes blank again. thank you!
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 15, 2011 | HP Compaq WF1907 Monitor
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Can not diaplay when connected to external TV tuner Box(fontech)
'The Monitor goes blank when the box is powered' what does that mean exactly? what box? What was the monitor doing before the said box was pwered?
Jun 04, 2007 | BenQ FP91G+ (Black)
Acer AL1916W 19" LCD Monitor Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
