Question about Canon PowerShot Pro1 Digital Camera
Problems with picture
Recently when taking pictures, they are completely washed out when reviewed. They look either over exposed or just white white horizontal lines running across the picture. The battery is charged and I went to the manual and put the camera back to it's default settings. The camera has never been dropped or exposed to elements. The manual does not approach this problem, other than white balance and the exposure meter which are set exactly to where they should be. Could the CF card be the problem? Please see sample photo attached.
Re: Problems with picture
I think that its because you are on spot metering.
take it off spot metering and also make sure that you exposure is on 0.0
i allways use P mode.
my email is
Posted on Nov 05, 2007
0 characters
3 Points
Recently, I have been experiencing trouble with my Nikon Coolpix P2. When I take photos, the picture comes out with faint white lines across them. The screen itself is fine, but once I press the shutter,...
Hello - from what you said - it sounds more like a sensor problem in the camera.
If the screen looks OK while sizing up a picture , then 'click' Image is stored on sensor which is read as one LARGE matrix of dots and stored into memory.
If the white lines start at this point - ie. viewing the picture while in camera and then after download.
Then, the problem started at the sensor.
I just did a ( and did a search for problems - and NONE apart from Wi-Fi connections to Windows7 -- all reviews were great.
I would connect Nikon to see what they recommend . -- Ray
Jan 23, 2011 | Nikon Coolpix P2 Digital Camera
Why is it that my pictures taken outside come out all white?
Hi. The camera could be faulty but it could also be because the camera settings have been changed so anything you take in good light is is 'over exposed'.
Try restoring all the options in the cameras menus to the original settings by using the review menu options of the camera e.g. on Samsung cameras this can be done as follows:-
[Setup2 Menu> 'Initialisation']
Then try taking some pictures with controls on 'Auto' at first.
Jan 16, 2011 | Digital Cameras
Outdoor pics completely washed out Cannon S5 IS Power shot
Try going into the review menu, choose setup and then choose 'reset all' This should re-set all shooting settings to automatic and solve the problem. If that doesn't do the trick, your sensor is probably damaged - not good news - sorry
Jul 25, 2010 | Canon Digital Cameras
We have a canon powershot A410 digital camera with 3.2 mega pixels (purchased brand new in fall 2007) and recently, whenever we take pictures outside, they come out completely white (overexposed). The...
Hi there its a chance of sersor damaged. He not able to read the light. Thats why outside image are over exposed. I suggest you visit service center for check or repair the lens sensor.Thanks.
Apr 07, 2010 | Canon PowerShot A410 Digital Camera
Can't take good pictures with new Canon Rebel xsi
You will need to read the manual. I f you have a basic understanding of how ISO, shutterspeed & Aperture width combine to determine the 'right exposure.
Try this:
Set the camera to Av (aperture priority mode). Half press the shutter button and see the light meter indicator to see how well exposed your shot will be. For most cases you would be aiming for a value of 0 (properly exposed). The metering mode determines what part of the frame is used to compute the correct amount of light. For starters begin with pattern metering. Try and aim for a shutter speed of 1/125 or more if you are using the 17-55 mm EF-S f3/5-f5.6. Try and shoot at 40 mm F/5.6 (in Av mode this can be set by rotating the dial near the shutter button.
All the best
Mar 29, 2009 | Canon EOS Rebel XSi Digital Camera
Pictures washed out
Washed out I would guess looks like it's all white or a lot of white instead of the colors on the pictures. My guess is that your camera is over-exposing the pictures. Usually keeping it in automatic should solve your problem. But if it still doesn't, then it might be that you have an offsetting function that I think is called EV, which is either a plus or a minus function. Plus for over-exposing and minus or under-exposing. Read the manual and look for this function. Usually keeping it on auto is enough. Let me know if this helps.
Jul 15, 2008 | Casio Exilim EX-S500 Digital Camera
its sounds like the camera is over exposed and the shutter is not functionaling correctly. qualified tech to look at camera.
Jun 19, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Taking photos
I have the same problem too with my a430, when i shoot outdoor, it's like over exposed, more of a white, but it's good indoor shooting aside for some horizontal lines. i already reset all the settings, still nothing changed
Mar 03, 2008 | Canon PowerShot A430 Digital Camera
Canon PowerShot Pro1 Digital Camera Logo
156 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
