Question about Canon PIXMA iP3000 InkJet Photo Printer
No power light on after putting in new cartridges
    Master:
  • Canon Master
  • 641 Answers
Be sure the cartrigde are ok
Posted on Jun 23, 2014
Why want my printer work?
If you are speaking of the power light not coming on then please check to see if you have the printer powered on into a 110 AC outlet. Also check to see if you have the ink cartridge installed properly and not upside down or reversed. Make sure it is not the old cartridge inside. Try a new cartridge as well.
Feb 20, 2015 | Epson Stylus Nx430 All-in-one Inkjet...
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Printer not accepting new black ink cartridge
put that cartridge in and perform a head cleaning process, and allignment... follow the procedure (2 or 3 times if needed) and in the end, shut down the printer, disconnect usb cable (both end), then wait for some time, aprox. 20 sec. and then put both end in again, turn printer on and wait for ready signal or some sort of confirmation that all is ok... If not, replace or update the printer driver and software, or reinstall all printer software.
Apr 22, 2014 | Epson R1900 Printer
When i turn the printer on the ink light and paper light are flashing back and fore and nothing works
You should check your cartridges. If one of them is empty, usually the printer won't print. Your cartridges have chips on them, and that chip determines how much you are going to print. Usually, when both lights are flashing, and nothing works, it has something to do with the cartridges.
If that is not the case though, please leave me a comment, as I would love to help!
Mar 07, 2010 | Epson Stylus Photo R220 InkJet Printer
Yellow cartridge warning light showing and printer does not recognise cartridge. Had artanium bulk system attached for 12 months, so the system has been ok for last 12 months. put standard epson cartridge...
First try power cycling the printer to reset the chip on your bulk cartridge (turn off printer, unplug, wait 30 sec, plug in, turn on). If that didn't fix it then you may have damaged the chip on your bulk cartridge with static electricity when you removed it from the printer. If the chip is damaged you need a new chip if you can get it or a new bulk cartridge (to get the new chip).
Oct 22, 2009 | Epson Stylus Photo R1800 InkJet Printer
Check print cartridge light blinks
pull the cartridges, with the power turned off swab w/ alchol swab the communication ports that the cartridges fit into, let dry then reinsert the cartridges and turn on the printer. The com ports get infiltrated with ink wont read the new cartridges.
Oct 12, 2009 | HP PSC 1315 All-In-One InkJet Printer
Red error light stays on says needs black ink but i just put a new one in
the main issue here is that your printer don't recognize your new black cartridge.
try shutdown your printer and on it again or long press on your power button ..
and your also to open close your main door of your printer..
so that it will recognize the full black cartridge.
May 18, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson 2200 ink replacement light stays on
I had the same problem with the light black and light magenta as well. It took trying only one new cartridge with the light magenta before it worked.
The light black took 4 new cartridges before it worked. I had called the Epson support center on this problem and after going through suggestions they made that did not work, I told the guy I had another new cartridge on hand. He said to go ahead and try it. This time the printer worked. He took my name and address and said the other cartridges were faulty. Epson is sending me new replacement cartridges at no charge.
Dec 04, 2008 | Epson Stylus 2200 InkJet Photo Printer
Print cartridge
This may sound simple, but did you remember to remove the tape covering from the ink cartridge before installing it? If so, run a self-test and let me know the results:
1. Turn the printer ON.
2. Press and hold the POWER button.
3. Press the RESUME button FOUR times.
4. Release the POWER button.
You should get a nicely printed self-test. If it fails, there may be other troubleshooting methods we can employ.
I hope this helps!
Regards,
Char1ieJ
Sep 08, 2008 | HP DeskJet 3820 InkJet Printer
Hp d1341 not printing
dear maxin
when light blinks it means that one of the two cartridge is not ok.
Do one thing, put out one of the cartridge and then close the door of printer, if the light blinks, then do same with the other cartridge.
If you can borrow the two cartridge from anywhere for a minute. Your problem has been solved.
because this problem is related to cartridge.
Nov 06, 2007 | HP Deskjet D1341 InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
old marine
old marine
