Question about Garden
Need manual for spray doc gilmour Sprayer
I have lost the manual..and need directions to use it.
5 Suggested Answers
Biggdex35
  • 333 Answers
SOURCE: Weee killer leaks from my Gilmour sprayer finger
Im pretty sure that is all it is. The pressure is by how many times you pump it up. Its just on or off. Sounds like It needs to be cleaned real good, and put soap in it befor you put it bak together. Also there is a screen if you hold the handle and turn the trigger part and unscrew it.
Posted on May 11, 2010
Testimonial: "Thanks for the reply Bigdex!"
  • 623 Answers
SOURCE: 486 Sprayer, lost instructions, sprayer lable washed off
See if this helps:
http://www.gotosprayer.com/sprayers/hose-end-sprayers/gilmour-dial-a-mix-hose-end-486
Posted on May 25, 2010
  • 231 Answers
SOURCE: i need the owners manual for the ortho dial n
From forums.gardenweb.com
"The instructions on Ortho Garden Disease Control (Daconil) give directions for use in the dial and spray. Set dial at 4 Oz. Add 1 TBS Daconil and 7 TBS water for each gallon you want. I am using the dial and spray and don't see as much residue as when I was using a pump spray.
Posted on Jul 03, 2010
AndrexT
  • 16199 Answers
SOURCE: I need a manual for my Gilmour model 2000P spray doc garden innovation 2 - 2 1/2 gallon
That is just a simple pump sprayer. Your manual is here
Gilmour Professional 2000P Manuals
Posted on Mar 17, 2017
How to fill gilmour spray-doc
All sprayers have a cap that turns anti-clockwise. With all of these you push the handle down and turn firmly.
Lawn Garden Gilmour Garden Watering
Mar 29, 2013 | Gilmour & Spray Doc& Poly Tank Sprayer...
How do yo get the sprayer to actually spray there is no pump to build the pressure to let the spray out. Is there instructions to the sprayer I have missed placed mine if there was some in the box
Here is the web site link for your sprayers manufacture. on the bottom rt is the model you can choose yours and get the manual you need. as you know there is usually some way to pressurize the tank, either hand pump or air pump. This should help and if you need more help please contact me. Thank you http://www.gilmour.com/tips-tricks/
Jul 13, 2011 | Gilmour Garden
Water leaks out of the bottom
If you see water leaking it might be that the plastic has a broken, try to seal it with super crazy glue.
Thanks
Jul 01, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
It will not spray
Your pump cam follower may be broken, such that the pump is just not working. Good news, you don't need to buy any new parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmour provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business. Since the higher the wheel speed the more stress there is on these tabs, I would not recommend moving the wheels any faster than what occurs with a slow walk.
See photos at:
http://s911.photobucket.com/albums/ac317/vonoretn/Gilmore%20Wheelpump%20sprayer/
Jun 04, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
My gilmour wheelpump sprayer just quit spraying. It appears to not be building up pressure. I have cleaned out the valve and screen on the bottom, removed and rinsed out the hollow oval 'ball'...
Your pump cam follower may be broken, such that the pump is just not working. It happened on mine. You don't need to buy any parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmore provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business.
See photos at:
May 11, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
I have a 3-gallon gilmour sprayer--has worked well-only several month old-able to get good compression but can not get anyspray-even after taking apart and rinsing your help is appreciated thanks ...
This situation sounds like a plugged hose. Keep taking apart and you will find something plugging a small orifice, somewhere... Always flush with clean water after each use, many garden sprays crystalize over time......
Apr 24, 2011 | Gilmour & Spray Doc& Poly Tank Sprayer...
Won't hold air & pump up/
I loss pressure, read the manual, took the slide out and saw that the o-ring was crimped out of shape, thus the loss of seal and no pressure! Popped it back to position and it spray is now powerful as day 1...patience is rewarded!
Sep 21, 2010 | Gilmour & Spray Doc& Poly Tank Sprayer...
Replace 0-ring
all I want to know is how I can get a replacement o-ring ASAP without paying to discuss my needphone number and person to call would be helpful.
Mar 23, 2009 | Gilmour & Spray Doc& Poly Tank Sprayer...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
