Question about Canon PIXMA iP3000 InkJet Photo Printer
No power to the printer when plugged in and turned on
  • 2,509 Answers
Faulty power supply?
Posted on May 15, 2014
  • W.L. May 15, 2014
    Also check socket is working
Canon pixma mg5220 will not turn on
When you have sparks it toasts the chips even a good teck will ground themselves before opening a peice of equipment like that. I'm sorry to say but I doubt very seriously if either piece of equipment will work. I would also get rid of the surge protecter and have that outlet looked at.
Oct 14, 2015 | Canon PIXMA Office Equipment & Supplies
I have an HP photosmart plus b209a-m and I keep on getting this "unreadable images" error that keeps on popping up and it is very annoying. I was wondering what it was and how to get rid of it.
Turn-Off the Printer using the Power Button.
Unplug power-supply cord from printer.
Unplug Power plug from power outlet.
wait 30 seconds.
Plug cord back into printer.
Plug power cord into Power outlet.
Turn-On power using Power button.
Now when you check printer status, it will be OK.
Jun 18, 2011 | Office Equipment & Supplies
Cannot turn on the printer even if connections are ok ?
The only thing that could stop you from turning the printer on other than a broke printer is the power/power cord is not connected. The printer should turn on without a USB or parallel printer cable attached.
If no lights are showing when you try to power the printer, check the power connection in the back of the printer to ensure it is plugged in, check the plug into the adapter is connected and that the power cord's plug is connected to the wall outlet - if you have a power strip make sure it is turned on and the circuit breaker is not popped. Make sure that there is power to the outlet by plugging in something else to show it has power. If all of those check out ok and you have a meter, check for voltage at the power connector at the printer (pull the plug out of the printer and check voltage from inside the plug to outside the plug. It should be 18 vac.
If all of this is ok, there is something wrong inside the printer. Probably time for a new one as cost to repair is probably too high.
Oct 11, 2010 | HP DeskJet 810c InkJet Printer
X4530 InkJet Printer: printer won't turn on. Don't have ink cartridges i...
The printer should turn on even without the cartridges yet. Try this. Make sure the power cord is plugged in straight to the wall. Bypass any surge device or power strips. Unplug the power supply from the printer. It's the black box behind the printer where the power cord is plugged in. With the power cord still plugged in to the power supply, the LED around the contacts should lit solid green. If not, make sure the power cord is properly secured. If this does not help, you may have a defective power supply. If it does, insert it back in the printer in the correct position. Plug it hard just to make sure. If it does not power on automatically, press the power button. If this does not help either, I strongly suggest you contact Lexmark Technical Support for further assistance. Thanks.
May 18, 2010 | Lexmark X4530 InkJet Printer
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
Cannot turn on printer
Is the printer plugged into a power strip? Please make sure the power strip is turned on.
Also, please change the power cable for the printer as this can sometimes be faulty.
Have you tried to plug the printer into a different location, I mean into a different wall outlet.
Mar 24, 2010 | Canon PIXMA iP4000R InkJet Printer
My printer will not turn on
you can try plugging the printer to a different known working power outlet in the wall. If still not turning on, try to unplug the power supply (black box) behind the printer where the power cord is plugged in but the other end still plugged in the power outlet in the wall. The power supply should have a green indicator light on. If not, check any physical defects on the cord or the power supply itself. If on, plug it back in and make sure to plug it in correct position in the slot. Note that it can be plugged in incorrectly so just double-check the position of the power supply itself. Hope this helps.
Mar 08, 2010 | Lexmark Z2300 InkJet Printer
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Reset power when it 's plug in
as you are getting the error RESET POWER..
turn off the printer..unplug the power chord..connect the printer directly to the wall outlet..and then turn on the printer..if you are still getting the same error message..perform these steps..
1)unplug the power chord from the back of the printer..
2)press and hold the ON button..while pressing the ON button plug in the power chord to the back of the printer..
3)after you plug in the power chord do not release the ON button for 30seconds..
4)after 30seconds if the printer is off, go ahead and turn on the printer..
the solution should resolve the issue..if its still the same please get back would give you some more steps..
Mar 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer won't turn on.
Try to unplug the power cable for about 2 minutes then plug it back in. Check if you can turn it on now. Double check the power plugs. Try to plug on a different power outlet.
Oct 13, 2008 | Dell 922 All-In-One InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
old marine
old marine
