Question about Dirt Devil CE7000 Easy Steamer Upright Wet/Dry Vacuum
Unclog steamer so it will suck water? - Dirt Devil CE7000 Easy Steamer Upright Wet/Dry Vacuum
  • 20 Answers
To unclog any sort of water clog mix white vinegar 1/3 cup, with 2/3 cups of water, Than pour mixture into suction opening and let lie for about 5 minutes.
Posted on Jul 02, 2014
Hoover wind tunnel platinum not sucking. How do I unclog it
You have to take the bottom plate off and remove the roller, from there you should be able to see or find the clog ! Be careful putting it all back together, the screws can strip the holes very easily.
Feb 20, 2015 | Hoover Vacuums
Why want my quick steamer suck up dirty water?
Check the manual for filters. They are generally small and need to be cleaned after each use. Consumer Care at 1-800-237-7691
Jul 19, 2014 | Bissell 1970-R Carpet Cleaners
I have the Hoover SteamVac SpinScrub and in the middle of use it quit sucking up the water. Is there anything I can do to fix this problem?
first check top on dirty water tank make sure it it tight, if that is on correct then it is stopped up under the bottom of the steamer
Jun 22, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Water is leaking in the back and not going into
check bottom of reservoir thereshould be a rubber gasket make sure its in place or check to see if it fell out
Apr 08, 2010 | Dirt Devil Easy Steamer Upright Wet/Dry...
I love my hoover F5912-900 scrubber however it has stopped sucking up the water. Is there a place that it could be blocked with dog hair or other dirt?It blows out air, but does not **** up the dirty...
Hi Shirley. Im afraid I do not have a solution for you rather I have the same problem.exactly it only blows..My machine is brand new I was using it for the 2nd time only......i also cannot find anywhere to unclog this thing....I even took the front plastic pieces off???????? have you found out the solution yet? im at bryansargeant@hotmail.com if you have any advise for me !!!
Nov 06, 2009 | Hoover F5912-900 Upright Steam Vacuum
Mine sucks because it DOESN'T ****.
First check that the dial on the side of your steamer is set to carpet for carpet and tools for tools, I know this is simple.
Now make sure that the water tank is down properly. Sometimes the little rubber seals on the bottom of the water take pulls off and gets stuck in the base of the machine. Make sure you have the rubber seals on the bottom of the tank before you put the water tank onto the machine.
Aug 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Eureka Hotshot Enviro steamer
Remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Jun 08, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Wet vacuum not sucking up water
Usually when these units don't pick up the water, there is a seal or gasket missing or out of place. But you have a years warranty on this, maybe you should take it to a warrenty shop and have it checked.
Dec 13, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Dirt Devil CE7000 Easy Steamer Upright Wet/Dry Vacuum Logo
185 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
