Question about Klean-Strip 1 gal. Green Safer Muriatic Acid GKGM75006
What is the concentration of this acid? - Klean-Strip 1 gal. Green Safer Muriatic Acid GKGM75006
  • 2,509 Answers
Less than 25 percent but it is still strong acid
the data sheet is here
http://www.homedepot.com/catalog/pdfimages/54/543a31d9-26f5-4cb1-884b-c49abf30f5c6.pdf
Posted on May 15, 2014
What fossil fuels cause acid rain
all do
it is a result of burning sulphur based oil ( most crude oil has a sulphur content) that is converted to sulphuric acid during combustion
that is causes most old exhaust systems to "rust" out
it comes out into the atmosphere in the exhaust steam and when it is concentrated enough in the atmosphere comes down as an ph value as acidic in rain water
Nov 30, 2016 | Fossil Watches
How do I buy the BEST hylauronic acid powder and vitamin C?
This is probably because you intend to make your own combination to reduce wrinkles and aging of the facial skin.be careful.the higher the concentration of hylauronic acid the more likely you will burn off your skin by more than one layer.diy chemical peels are not something you should experiment with ...that is why the percentage of this chemical is restricted to 5%.you can buy high concentrations of this off eBay but trying to get pure is not something readily available to general public.or everyone would be down the burns unit having skin grafts.
Mar 01, 2015 | Cars & Trucks
We want to descale our CENTAC model C90MX3 compressor's intercoolers using SULFAMIC acid. What should be the concentration and the right procedure to descaling?
whats wrong with using plain ole citric acid I use lemon juice for my source works great cleaning up the aluminum and stuff , dont forget to wash off /out what ever you end up using cus if it cleans it up then its corrosive and if you dont get it all off it keeps eating it
Note : contain all run off and dont allow to enter any drains as it contains oil not an enviromenty friendly thing to get out
Mar 17, 2014 | Ingersoll Rand Air Tools & Compressors
Can you show me how to find the ration between ph and pka?
There is not a simple ratio between these two. See: What is the relationship between PH and pKa - Wiki Answers
wiki.answers.com > Wiki Answers > Categories > Science > Chemistry
when pKa = pH, there is equal concentration of acid and its conjugate base. pKa helps to understand the nature of acid and base like pH: .... Related topics: .pka ...
Jan 28, 2014 | Personalised Grandmas Wish List Print, Not...
Rust in gas tank
Not much you can do for this problem. The acid that attacks rust is phosphoric acid. and will be a starting point. IF the rust is flaky put some sharp edged pebbles in it and shake hard to help remove loose rust. (like sand blasting by hand). Use no other acids as they will attack the metal and not the rust. The stronger the phosphoric acid concentration the better. Can be obtained from large hardware stores as a rust converter.
Aug 16, 2013 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
What does pH stand for?
the p stands for potential and the H stands for Hydrogen, and it refers to the ability to attract hydrogen ions.
Jan 28, 2013 | Measuring Tools & Sensors
What types of protein (concentrate, isolate, etc.) do protein bars consist of?
Protein bars typically contain a combination of different proteins like whey protein isolate, whey protein concentrate, milk protein, and soy protein isolate.
Jan 24, 2013 | Health & Beauty
What product to use to remove the scale in a urinal ?
If you can get it use a product called sizzle. It is a very concentrated hydrochloric acid and it will do a good job but must be used with extreme care due to risks of acid burns and inhalation of fumes.You will probably only find this strength at a plumbing wholesaler. I have not used it personally but I have had people tell me that muratic acid also does a fair job. Hope this helps you. Thank you.
Feb 04, 2011 | Garden
My SUKAM Shiny 400va sinewave home ups is powerd half when utility power off. overload light glowing. But this ups running perfectly at the same load before.
There might be a problem in the battery acid concentration. Take the battery to a battery recharging shop. The specific gravity of the battery has to be 1.22-1.25 for a fully charged battery.(if your battery is lead acid type) Handling lead acid battery(or any other battery) without proper knowledge and supervision is very dangerous.Be cautious.
Dec 03, 2010 | Electronics - Others
I trying to work out how to use my ti83 plus -What is the pH and pOH of a 1.2 x 10 -3 HBR solution?
First you have pH+pOH=14
Thus pOH=14-pH.
The problem with you question is that you do not specify the meaning of the 1.2 x 10^(-3). Is it the molar concentration of the hydrpbromic acid HBr.
I am going to answer your question but I must make some assumptions. You can imitate the reasonning to obtain your answer, once you have decided or looked up what the numbers mean.
Lets assume that HBr concentration is 1.2x10^(-3) mol/L. Since it is a strong acid, it dissociates completely, releasing 1.2x10^(-3) mol/L H+/H3O+ ion.
Thus the pH is
pH=-log(1.2x10^(-3)).
The result is 2.92
Here is a screen capture of the actual calculation. The minus signs are the change sign (-) to the right of the dot. To enter the power of 10 (represented by the E in display) use the (2nd)(EE) key sequence. To access the content of (Ans) memory, press (2nd) (change sign)
Mar 07, 2010 | Texas Instruments TI-83 Plus Calculator
Klean-Strip 1 gal. Green Safer Muriatic Acid GKGM75006 Logo
111 people viewed this question
Top Klean-Strip Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Klean-Strip Tool and Hardware - Other Expert? Answer questions, earn points and help others
