Question about Eliminator Hudson Sprayer - 1 Gallon, Model# 30161
Why will sprayer not pickup fluid and build pressure?
I have changed "O" rings on pump piston.
1990 Gmc pickup truck has blow back at dip stick , how can I fix ?
Check PCV system. It may be time for the compression leak down test to see if rings are shot.
Feb 20, 2015 | GMC Cars & Trucks
I have no pressure in my flo-master sprayer after pumping
Make sure the tank pressure release is shut, or make sure the rubber o-ring under the pump is there. You should feel back pressure after a few pumps.
Jun 29, 2014 | Rl Flowmaster FLOMASTER 1 GAL SPRAYER ()
Why does Pump not build pressure
probably bad seals or ring or the relief valve is stuck open
Aug 29, 2012 | H.D. Hudson Hudson Pumpless Sprayer 2...
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
My four-year old PC pancake compressor starts fine but only builds up 60 psi no matter how I adjust the pressure regulator. The compressor motor runs continuously. I checked for air leaks and can't find...
First take off the head on the air pump and check the reed valves on the valve plate. If they got hot and warped or cracked they'll work to a point then no more pressure can be built up. Next check the pistion ring and cylinder wall. If either is damaged you'll only get so much pressure build-up then it will leak past the piston.
Mar 07, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a 3 gal. back sprayer. When you try to presureize the tank to spray, The pump seems to work but there is no pressure. If repairs are necessary, where in the Redding, Ca. area is a repair shop for...
Hi there
There are many possible reasons for your sprayer not pressurizing. If the pump lever is moving freely and does not seem to be building pressure while pumping it is possible that the O-ring at the valve is damaged, the seal in the pressure regulator is leaking, the piston or the collar is worn. Any of these problems will require disassembly of the unit and inspection of each part. If you do feel resistance building as you pump but quickly loose pressure you likely have leaks in the diaphram, it's seal, the pressure cylinder or the tank itself.
If you are comfortable disassembling the unit and inspecting the parts for wear or damage most of the individual replacement parts are fairly easy to replace and readily available online from Solo or at many retail outlets and supply companies. Solo has done a great job with how-to videos and instructions for each procedure on their web site www.solousa.com
If you are not comfortable disassembling and repairing your sprayer yourself you can try contacting a mower/equipment repair shop in the Redding area as is seems the nearest Authorized Solo sprayer repair center is Cloverdale Saw in Cloverdale CA, 707-894-2273
Dec 31, 2010 | Solo Backpack Sprayer 3 Gallon Capacity,...
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Nov 13, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
Trying to find how i can build my own trailer mounted sprayer for dust control
No need to re-invent the wheel when building your trailer mounted sprayer. Your local Northern tool Store, or at the address below,
http://www.northerntool.com/webapp/wcs/stores/servlet/category_6970_166839
you will find all the parts that you will need to complete your project. I have purchased several different types of sprayers, tanks, pressure pumps and parts from them over the years. They have a helpfull staff and most parts are in stock. Take a look at ready made trailer mounted sprayers there to pattern yours after then design in your special needs.
My first portable sprayer was made from four 55 gallon drums loaded onto the back of my pickup. For the pump I used a modified 2" trash/water pump reduced to 1' pipe then seven nozzles. Worked great however 220 gallons of water did not last very long. Problems began with the weight of water in large quantity. I decided I needed about 1000 gallons and found that I needed to deal with about 7500 lbs of weight. Oh well, enough already, good luck with your project and email if you have questions.
May 11, 2009 | Cam Spray 25006PM 2500 Psi Cold Water Gas...
LAWN SPRAYER PUMP WILL NOT SUCTION
Disconnect the sprayer boom hose from Y splitter, and dd another Y splitter, then reconnect the boom hose to one side of the added splitter. Add a washing machine supply (female/female) to the other side of new Y. now attach garden hose to washing machine line and turn on the water faucet with pump running. This will charge and/or backwash the pump. Once pressure is achieved, turn on the boom and check for fluid movement, then turn the washer supply valve on Y to off, and disconnect. The pump should be primed and be cycling fluid from tank and back to tank. Ready to shift to boom for use. I leave the washer hose and assembly zip-tied onto sprayer for easy future priming, and pump wash between uses.
May 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Eliminator Hudson  Sprayer - 1 Gallon, Model# 30161 Logo
53 people viewed this question
Top Eliminator Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Eliminator Garden Expert? Answer questions, earn points and help others
