Question about Plano Golf Guard Deluxe Hard Travel Case
Where can i get replacement latches for my plano 72001 golf guard case?
Lasko table fan model 4916 , I would like to know how to take it apart to clean it.
Kevin-
LASKO's typically have latches or clips that hold the front fan guard to the back fan guard.
Flip latches or carefully remove the plastic clips. This will reveal the 'nut' that secures the fan 'blade assembly'. Note, the nut has 'lefthand' thread so to remove it, turn it clockwise to remove.
The fan blade assembly can be pulled / wiggled free.
The fan blade assembly can be washed with water / wiped with a cloth.
Another nut (righthand thread) secures the back half of the fan guard, remove it and remove the guard.
That should do it.
Dec 18, 2014 | Dryers
My 21" Plano TV , replace the Picture Tube becous
It sounds to me like it has the wrong scan coils fitted to the replacement tube and there is no fix for that. You will need to fit the correct tube or have the old tube re built.
Dec 28, 2010 | Samsung Televison & Video
How do you change a serpentine belt on a 2007 forenza suzuki
Hi, raise vehicle, support with safety latches/jackstands, remove splash guard from passenger front wheel well. Using a box-end 15mm wrench release tension from automatic tensioner. Noting belt routing, remove serpentine belt, replace with new one, reinstall splash guard.
Sep 01, 2010 | Suzuki Forenza Cars & Trucks
My VW Golf (2001) leaks when it rains, leaks above my sun guard, around the sun roof & rear pannel on the drivers door. Why?
the weather striping sounds like it needs to be replaced they get brittle and dont seal as they should next time you go out to look at it see if there are any cracks or if it is hard and worn it also could have just simply slid and if thats the case most times you can slide it back
Apr 30, 2010 | 2001 Volkswagen Golf
HOW TO INSTALL SERP BELT ON 07 SUZUKI FORENZA
Raise vehicle, support with safety latches/jackstands, remove splash guard from passenger front wheel well. Using a box-end 15mm wrench release tension from automatic tensioner. Noting belt routing, remove serpentine belt, replace with new one, reinstall splash guard.
Dec 30, 2009 | 2007 Suzuki Forenza Sedan
22" NEEDS NEW LATCHES
You can also reach us at:
Ph: 1-800-226-9868
Plano Molding Co.
431 E. South St.
Plano, IL 60545
customerservice@planomolding.com
Jun 29, 2009 | Plano 22" Pro Tool Box
Change tke hood realase cable in hyundai elantra
Service and Repair Notes HOOD LATCH CABLE REPLACEMENT Remove the following items: Hood release handle. Radiator guard. Hood latch. Wheel guard. Using a clip remover, detach the clips from the body, then remove the hood latch cable (A) from the vehicle. NOTE: Take care not to bend the cable. Installation is the reverse of removal. NOTE: Make sure the hood latch cable is connected properly. Replace any damaged clips.
Jun 08, 2009 | 2005 Hyundai Elantra
The rear wiper and washer on my 2005 golf 5 GTI 2.0 FSI stopped working
the most common problem is you havn,t shut the tailgate properlly.you may have it on just the first latch in wich case the rear wiper wont work.give the tailgate a good slam to make sure its shut.
Jan 31, 2009 | 1997 Volkswagen Golf
Plano Golf Guard Deluxe Hard Travel Case Logo
244 people viewed this question
Top Plano Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Plano Golf Expert? Answer questions, earn points and help others
