Question about Toshiba Dkt2010-sd Strata Dkt 2010 Sd Display Charcoal
How to turn ringer on - Toshiba Dkt2010-sd Strata Dkt 2010 Sd Display Charcoal
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 183 Answers
Utilize google to find a manual. utilize manual to find information. utilize information to change settings as needed.
Posted on Jun 03, 2014
HOW DO I TURN THE RINGER ON. HAND SET READ RINGER OFF
Temporary ringer off While the handset is ringing for an outside call, you can turn the ringer off temporarily by pressing {OFF}.Adjusting the base unit ringer volume Press {^} or {V} repeatedly to select the desired volume.To turn the ringer off, press and hold {v} until the unit beeps 2 times
Sep 22, 2011 | Panasonic KX-TG5632 Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Can i turn down the base ringer (or turn off) on my vtech dect 6.0?
Welcome to FixYa!
The base ringer is dependent to your handset ringer. If you lower the volume or turn off the handset ringer, the base ringer will follow.
Thank you for using FixYa.
Have a great day.
Jas247
May 17, 2011 | Vtech Cordless 6041 Phone
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
Ringer was accidentally turned off. How to turn on ringer.
I found a free online owners' manual and read it. Thanks, though.
Apr 13, 2009 | Uniden DECT2085-3 Trio Cordless Phone
Model GE 27951 - Unable to Turn Ringer back on
The headset volume is turned to zero. Hit the "menu" key on the headset and it should take you to "ringer setting", hit select for the ringer volume and turn the volume up. Not very intuitive but that should get you going!
Jan 28, 2009 | General Electric 27951EE1 - - Phone
Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
May 10, 2008 | Uniden Cordless Phone
Ringer
Hold the Low volume key on the base unit for sometime. A beep will sound that means the ringer of the base unit is off.
Feb 18, 2008 | Panasonic KX-TG5632 Phone
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Jan 17, 2008 | Lands Phones
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Toshiba Dkt2010-sd Strata Dkt 2010 Sd Display Charcoal Logo
66 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
