Question about Stanley Garden
Hudson sprayer 63164
My hudson sprayer 63164 will not pickup fluid? I have changed "O" rings on pump piston with no results. Do you have a suggestion?
3 Suggested Answers
  • 332 Answers
SOURCE: I have the hudson eliminator sprayer and squeeze
IF your sprayer is full you should be good to go after 20 or so full stroke pumps
If it is not spraying unscrew the adjustable tip and clean out the little holes around the end
If you leave spray in the unit after using it it will get crudded up and plug up
Posted on Mar 08, 2010
jyackle5
  • 8197 Answers
SOURCE: how do i fill my hudson sprayer
On the link below page 2 will tell you how to fill your sprayer.
http://www.hdhudson.com/PDF_files/poly-sprayer-instruction-sheet.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jun 27, 2010
Looking for hudson sprayer repair kits
you will need to contact them from here
http://www.hdhudson.com/contact-us
they will direct you to the closest reseller of their kits or they can ship one to you.
Dec 29, 2012 | H.D. Hudson 2g Yard N Garden Sprayer
Why does Pump not build pressure
probably bad seals or ring or the relief valve is stuck open
Aug 29, 2012 | H.D. Hudson Hudson Pumpless Sprayer 2...
How do i fill my hudson sprayer
Jun 27, 2010 | Eliminator Hudson Sprayer - 1 Gallon,...
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
I have the hudson eliminator sprayer and squeeze the trigger I just get one burst of spray and then a couple of drips. I do have it pumped up all the way. What is the problem?
Mar 08, 2010 | H.D. Hudson Hudson, H D Mfg Co 1 - 1/2gal...
How do you get pressure into the sprayer. I have pumped and pumped nothing seems to happen
IT'S AN INTRINSIC FAULT WITH THIS PIECE OF JUNK. THE DIAPHRAM INSIDE THE PUMP TUBE IS ABSOLUTE GARBAGE, THEY DON'T EVEN WORK PROPERLY WHEN BRAND NEW, BUT AFTER A FEW MONTHS THEY WON'T PRESSURISE AT ALL. BUY A QUALITY SPRAYER, THAT REPLACEMENT PARTS ARE AVAILABLE FOR.
Jul 23, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
From jdwillia on hudson sprayer
I poured hot water in the top and let it soak for ten minutes. Removed pressure valve and it broke free.
Jun 16, 2009 | H.D. Hudson 2g Yard N Garden Sprayer
I have a hudson classic sprayer and have no instructions.
The pumping mechanism should unscrew from the plastic bottle. Push the handle all the way down and try to unscrew the pump while holding the bottle steady.
Immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
Nov 18, 2008 | H.D. Hudson 2g Yard N Garden Sprayer
Garden Logo
Top Stanley Garden Experts
Dennis Key
Dennis Key
Jim Goldsmith
Jim Goldsmith
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stanley Garden Expert? Answer questions, earn points and help others
