Question about Cell Phones
Need lt26w sony, sim ways - Cell Phones
Www sonyericsson com support
It's high time you change its battery boss.
Jul 20, 2014 | Sony Xperia acro S LT26w Unlocked Quad...
Phone won't start up. just does a constant loop of the word sony then goes dark and does it again. over and over. have held down power button and volume buttons at the same time. Vibrates, then keeps doing...
If the phone is unlocked you could have gotten it stuck in a loop. I had similar problems when I flashed a ROM that was not meant for my phone onto it. If you have a backup saved you will need to re-access the boot loader and reload the backup of the saved ROM. If you can not access the boot loader I would suggest taking it to a cell phone repair shop. It would not be a difficult fix for them since it will most likely be flashing a couple of files to your phone.
Sep 10, 2013 | Sony Xperia acro S LT26w Unlocked Quad...
Sim insert solution
Sim insert solution: 4 ways to put it in. 2 are easily wrong. Answer this question? Chevy car boot... That`s current info amount.
Aug 17, 2013 | Sony Ericsson W200i Cellular Phone
Slow android response on xperia acro S
check for any software updates available.
if any update to the latest version..
u can try to install clean master on your phone then remove junk files..
if the above steps do not solve your problem then factory reset your phone but before that make sure you have a backup of everything on your phone
Aug 06, 2013 | Sony LT26W XPERIA ACRO S WHITE Unlocked...
Dear sir i have a problam of sony ericsson j20i sim ways please help me
thi problem is nothing but sim ways to the conecting strait ic in this jupers
ways
Oct 20, 2012 | Sony Ericsson J20i Cell Phone
Sony ericsson j20i insert sim ways
dear sir i have a sony ericsson j20i phone this have not taker any sim please give me the hadware solution of this proublam
Dec 21, 2011 | Cell Phones
Insert correct sim
first you need to open the back case of that phone.....,,then after opening the back case...remove the bateery from its position..then find where is the sim slot takes place after that put now the sim card to its proper way...the proper way in slotting the sim is place on the top of the card slot...
May 16, 2011 | Sony Ericsson M600i Cellular Phone
I have a Sony Ericsson T303 which I can't use because it says invalid SIM. any ideas what I can do to validate the SIM. It is the right SIM for the phone but the problem started when I put in a pin number...
you will need to contact your network to get the puk code to unlock the original sim or get the phone unlocked to any network which there is no free way of doing on that model
May 19, 2010 | Sony Ericsson T303 Mobile Phone (Shadow...
NEED PUK CODE FOR SONY ERICSON W850I
The PUK code is a code associated with the SIM card and not with the phone.
You have only two ways to get rid of the PUK code. Either you replace the SIM card , or you call phone provider that issued the sim cadr (eg. At&T, Virgin, Tmobile , Vodafone, Telecom etc.)
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore. d dd
May 18, 2009 | Sony Ericsson W850i Cellular Phone
Cell Phones Logo
50 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
