Question about Estate Dryers
Estate TEDL6408 How to remove the front panel.
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
You need to open the top slip a putty knife on the edges in front and find the spring push spring in twords back the top will lift ,two screws in lint screen and top up screw on each side nerar top ftrom inside
Posted on Jun 29, 2014
  • marlin siecinski Jun 29, 2014
    Always unplug the dryer before working on it
Where is the lent trap on the estate washer
If it is like my Kenmore washer, you need to remove the front panel at the base of the machine. You should see the trap front and center, caution when you open the trap there will be water coming out. good luck
Sep 06, 2014 | Estate Washing Machines
How Do I replace the Timer on a fex831fs4?
U CAN ACCESS FROM BEHIND BUT BE SURE AND REMOVE CAP AND CONNECTOR AT FRONT
Jun 01, 2014 | Estate TAWX700JQ Top Load Washer
Estate dryer will not heat. Does not even start to heat up.
You could have a broken igniter element. to trplace this you must first remove the front panel. To do this remove the lint screen and you will see 2 screws, remove them - next take a broad blade putty knife and insert aproxametly 1 to 2 " where the top meet the front panel on each side and the top should pop up, next rempve the 2 screws on either side of the front panel and the front panel will remove. Down at the opening of the funnel you will see a ceramoc disk with an element attached if this is broken that is why you do not see the glow.
Feb 01, 2013 | Dryers
I need to replace the belt on my Estate dryer. How do I get to the belt?
Generally speaking on front load whirlpool dryers the belt can be accessed from the rear by removing the back panel. Good luck.
Dec 13, 2011 | Estate Dryers
My Whirlpool Gas Dryer Estate Model # TGDS680BW1 will not tumble when I turn it on but the motor still runs. How can I fix it?
The problem is likely the dryer belt . Here is a video on replacing a dryer belt. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Sep 17, 2010 | Estate Dryers
Whirlpool estate dryer stopped working mid-cycle and will not turn on at all now
The thermal fuse is bad . Located on the blower box , a small white piece , with 2 wires attached to it . Have to remove the front panel to access .
Aug 09, 2009 | Estate Dryers
HOW DO I REPLACE THE BELT
2 screws at bottom front, pull out slowly from bottom first. Remove the door switch wiring. Then you will see the rest. Note how the belt rides thru the pulley and onto the motor. Belt # 341241, available for $11.99 at timerking.com. Hope this helps!
Jan 07, 2009 | Estate TEDS840JQ Electric Dryer
Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
Dryers Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
