Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Model 81 when i run disposal it pull water @ wast out.then when i cut it off water comes back into sink.
  • Ace Hardware Master
  • 9,742 Answers
Roto rooter the drain pipe in the wall. It's plugged. The water goes up the vent pipe to the roof that's why the water comes back in the sink when you shut off the disposer.
Posted on Jul 15, 2015
  • 10865 Answers
SOURCE: GE disposal won't drain
It sounds to me like the knock out plug leading from the disposal has never been removed. Remove the drain like and you may find that there is a thin plastic wall preventing any water from leaving the disposal. Just place a small screwdriver in the opening up against the plastic barrier and tap it out with a hammer. good luck
Posted on Jan 21, 2009
rcampsr
  • 90 Answers
SOURCE: garbage disposal doesn't drain
Sometimes what happens is that when they install a garbage disposal the pipe coming out of it ends up being lower than the pipe exiting the pea trap thru the wall under the sink. If it is a dual kitchen sink this is very common. Being lower than the exiting pipe causes water to stay in the bottom of the disposal and not just the pea trap. If you have a side by side sink in the kitchen and the water is backing up in the other sink also then more than likely the pea trap has a blockage. It is not common for the straight line from the pea trap going thru the wall to become blocked, but it does sometimes happen. The biggest cause of this is poring hot grease down the drain. It is just about the point that it cools enough, sticks and hardens plugging the drain pipe.
You probably should have a plumber look at it and make sure everything is running downhill under the sink. The only place that water should set in the plumbing is in the pea trap so that odor from the sewer does not come up into the house. Without actually seeing it, it is hard to tell exactly what is happening. The pea trap is easy to clean, put a really big pan under the trap, make sure you have emptied as much water out of the sink as you can, then with a big pair of channel locks unscrew the two nuts that hold the pea trap in place and let the fluid drain from it, then finish unscrewing it from the pipe. You can then clean it out and check the pipe thru the wall for blockage. When reassembling it, screw it all together loosely and then move the pieces around while hand tightening each joint so the they have no pressure on them, then use the channel locks to finish tightening the nuts. Don't over tighten them because they have nylon seals in them that compress to make the seal. Just tight enough to seal and not leak. You should be up and running again unless the plug-up is farther down the wall pipe. Good Luck, RAC
Posted on Apr 21, 2009
  • 35 Answers
SOURCE: Our Badger garbage disposal is filled with water,
Sounds like the unit is fine but I think you have a plugged drain.Put an empty bucket under the trap and take it apart.Next remove the tailpiece from the disposal and clean it out.If everything is clean and you can't find the clog you will need a drain snake to remove the clog in the drain pipe.Good luck.
Posted on May 12, 2009
protek480
  • 1714 Answers
SOURCE: water leaking by discharge tube
All you need to do is tighten the two screws on the discharge pipe (right on the side of disposal.) There is a gasket that needs tightening under the pipe fitting.
Posted on Sep 07, 2009
  • 744 Answers
SOURCE: insinkerator badger 5 runs sink wont drain
Properly piped, your arrangment should look similar to this picture so that there is a separate trap for the disposal and the other sink basin.
Posted on Mar 05, 2010
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
Dec 04, 2015 | Garbage Disposals
Tip
Install a new garbage disposal
A garbage disposal can be either installed from scratch or instead of an older disposal.
First of all you need to shop for the disposal that best matches your needs.
For example you should consider whether a noisy disposal would be a problem in your household, what kind of plumbing you have, or if you have kids or not.
Here are some guidelines:
- Choose a motor suitable for your household. There are models with lower or higher horsepower, for smaller households with small amounts of food waste, or larger households with more food waste.
- Consider the features that you need. Like a quieter disposal, or one made of stainless steel, or one that connects to the dishwasher. There is a vast variety of options and prices.
- If you have kids you might want to consider getting a batch feed disposal rather than a continuous feed one. The batch feed disposal is a bit more expensive but it is also safer for kids, as it requires the use of a stopper prior operation. While the continuous feed disposal starts running when you flip the switch on and will continue running a bit also after you switch it off. This can be dangerous if someone drops utensils down the drain or sticks a hand inside the disposal.
- If your plumbing connects to a septic tank you need a disposal made for septic tanks.
After shopping for the right disposal, you need to get hold of these tools you'll be needing for the installation:
- Electrical cord
- Disposer wrench
- Hacksaw
- Screwdriver
- Water pump pliers
- Plumber's putty
- Safety supplies: goggles, dust mask, gloves
When you are ready, the first thing to do before installing the new disposal is to turn off power and make sure nobody turns it back on while you work.
Now you can proceed removing the old disposal.
If the old disposal is attached to a dishwasher, loosen and detach the dishwasher hose with a screwdriver.
Then with the wrench unscrew the slip-nut connecting the disposal to the "P" trap waste line, putting a bucket under the trap to catch any waste water sitting at the bottom of the trap.
Remove the old disposal with the screwdriver and take apart the rest of the mounting assembly, including the ring on the sink sleeve, the sink sleeve, the flange, the fiber gasket and the old plumber's putty. Make sure to clean well the sink, the sleeve, the flange and sink opening from old putty and grime before installing the new disposal.
You are now ready to wire your disposal, whether it came with appliance wires attached or if you need to attach them yourself following carefully the manufacturer's instructions (after unscrewing the cover plate beneath the disposal and then screwing it back in).
The next step is installing the drain flange and mounting ring by rolling some plumber's putty between your hands to form a snake about half inch thick and 10 inches long and applying it to the underside of the drain flange. Insert the flange into the drain hole and press down to attach it. You can then snap on the backup ring, fiber gasket and mounting ring.
Use a knife to cut away the extra plumber's putty that will have squeezed out around the flange.
At this point you can place the disposal into the mounting ring making sure that the disposal's outlet is facing the drain pipe connection, and tighten it until it stays in place.
Connect the P-trap, using the hacksaw to cut the discharge pipe to size if too long, and attach it to the outlet of the disposal. Make sure to connect it properly by reading carefully the manufacturer's instructions. If your disposal connects to the dishwasher attach the discharge tube to the disposal as well.
You can now turn the power back on and run cold water into the sink, turning on the disposal to make sure it's working and to check if there are any leaks, and running some food through the disposal to make sure it grinds and disposes properly.
You can also use this video to follow more visual instructions and help you in the process.
http://www.youtube.com/watch?v=DPaMgqnLW1M
Make sure to mantain your garbage disposal in good shape by avoiding grinding certain items like hard shells from shrimps, crabs or other shellfish, unpopped popcorn kernels and hard bones, by avoiding fibrous or starchy foods like banana peels, celery, potato peels, corn cobs, artichokes, fruit pits and hard seeds like avocados or peaches, onion skins and egg shells, as they create clogs and membranes that will ruin the disposal, and by cutting down big pieces of food into smaller pieces.
It is also best to run cold water while the disposal is on, keeping both water and disposer running for about a minute after the sink is cleared. Cold water helps push food down, avoid overheating of the system and unlike hot water, doesn't melt fat, that would re-solidify as a blockage further down the drain.
on Dec 23, 2013 | Garbage Disposals
Tip
How to unclog a garbage disposal
Before you tackle this problem, you should understand how to use your disposer so you'll probably never have to deal with a clog again. You can easily use put a sinkfull of waste down your disposer without a hitch. It's all about controlling the amount of water mixed in with the waste. Your disposer is designed to break waste down to pieces a little smaller than a BB. This is efficient but without much water, the pieces will clump together right where the disposer connects to the drain line, and will cause a clog. Never turn on the disposer without a full flow of cold water. Cold water not only helps to cool the motor, but keeps any fat solidified so that it doesn't build up on the walls of the pipes. The full flow of water will allow the disposer to mix the waste in and it'll go right down the drain. The second thing you must control is the amount of waste that goes in the disposer. It's really a bad idea to put more than like half a cup of waste in the disposer without it running. Ideally you'd turn on the water first, then start the disposer, then feed the waste in. Listen to the disposer running with waste in it. It sounds different when the waste inside is gone. Use this to get yourself used to keeping up with its pace. The problem with any disposer is that they work so fast, they can grind the waste faster than the water can carry it away.
Whatever you do, don't use a chemical unclogging product. Over time, this can damage the metal components of the disposer, and if you have to call a plumber, they will charge you extra because these chemicals make their equipment wear prematurely and can burn the skin.
If water doesn't drain, make sure the problem isn't fixed by simply turning the disposal on. If the water just swirls around, you'll probably need a plunger. When you want to use a plunger to unclog your disposal, the easiest way is to use suction more than pressure. When you push down on the plunger, the pressure from it will cause the backed-up waste to compress even further and make it impossible to push water down. You want to push the plunger down so that it "leaks" water out, and, when the plunger can be pushed down no farther, make sure it then has a good seal on the disposal's opening, and yank the plunger up pretty hard. This will pull the backed up waste back, mixing it with the water and will probably unclog the unit in only a couple strokes. Be careful not to soak yourself when pulling up on the plunger. In a pinch, a full soda can will actually form a seal and can be used in place of a plunger for disposals that have a splash guard made of one piece. If water is backed up into the other sink bowl, that means the clog is in the trap and not in the disposer itself. One way to fix this is to make sure the other bowl(s) of the sink are firmly stopped up. If you use a stopper you'll most likely have to push down hard on the stopper while plunging the disposer to form a good seal. If none of this helps, you may need to take apart the sink trap. This can be done by loosening the two nuts on the part of the drain pipe assembly shaped like a "U". You then may be able to clean the clog directly out of the u-bend or you may need to snake the pipes. If you take the pipes apart, have a bucket under there to catch the large amount of that will gush out.
on Dec 07, 2009 | Plumbing
If the garbage disposal backs up the dishwasher fills with water
Plumbing codes vary in different locations. Some require the dishwasher hose to be connected to an air gap vacuum breaker mounted above the flood level rim of the sink. At the very least the hose should be run up as high as possible under the sink before connecting to the garbage disposer. To keep waste water from backing up into dishwasher.
Hope this helps.
Jan 14, 2014 | Dishwashers
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My in-sink-erator model 5-81 is just over 2 years old and is leaking from the sides whether it's running or not. Is there anything I can do or do I need to contact a professional>
Find out exactly where leak is coming from.
You say water is coming from the side... is that where the pipe connects? Then take apart pipe and reassemble pipe using instructions below, and use rectorseal on joints as described below..
Is water coming from where dishwasher connects to disposal? Then tighten the clamp.
Is water coming from top where disposal connects to sink? Run paper towel around top to check for moisture, and then use steps below to dissemble disposal and re-install same disposal.
Is water coming from a rusted hole in disposal. Then replace disposal using steps below:
Here are the disposal steps:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or change pipes.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment
Dec 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Motor comes on; but does not cut the waste. Water
The water staying in the unit suggests the drain is clogged. Usually this happens outside the disposal, at the T-junction in the drain lines. Unless your plumbing is *very* old, the drain lines should be PVC with large nuts that can be removed by hand.
Use a bucket below the junction as you take things apart to catch the water. Keep in mind that below each nut, inside the joint, there is typically a translucent washer (triangular cross section) around the pipe - don't lose this, or your joints will leak when reassembled.
This job isn't tough, but it is messy. If you have any doubts about reassembly, take photos before taking things apart, so you have a guide to work from.
Nov 26, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Blockage Maintenance
# Regularly remove any hairs that get trapped in the waste plug hole. # Keep small objects such as combs, medicine bottles and toilet rolls away from places where they could accidentally fall into the toilet. # Regularly flush the wash basin and bath or shower pipe work with hot water and a disinfectant to clear soap residue and prevent build up over time. # Don’t flush away large and disposable items such as sanitary towels, nappies or product wrapping as they can become caught in the drainage pipe. # Do not dispose of waste food scraps and cuttings down the kitchen sink. These are much better composted. If any items do fall into the sink pull the vegetable material out of the plug hole, do not try to poke through as you could impact the blockage making it harder to remove. # Never dispose of cooking fats down the drain system. As they hit cold water they will solidify. If there is absolutely no alternative you should dilute and emulsify the fats by mixing them with hot water and of detergent. Keep the water running for a minute after you have done this to keep a clear water flow. # For complete peace of mind, particularly if you are running a business you can request a regular drain surveys and get your drainage system checked regularly by a CCTV drain inspection service. This will give early warning of any potential blockages and also enables you to keep an eye on the structural condition of the drainage pipe work.
Aug 27, 2008 | Kohler Model 7202: Drain For Purist® Baths...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
212 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
