Dell 2350dn spotted print
Printer is brand new but in the box for 2-3 years. Toner blotches and spotting randomly on paper. See the same issue on 2 printers and have 12 more in boxes. Replaced cartridge to no avail. Going to replace drum but seeking expert advice.
Replacing the printer drum fixed the issue which occurred in approximately 25% of 16 printers stored unopened for 3 years.
Posted on Jun 12, 2014
  • 46 Answers
SOURCE: Dell 1600n has been ghosting lately
The 1600n AIO (all-in-one) is a laser printer. Laser printer use a statically charged "drum" to place toner on the paper. Your ghosting problem may be from the drum itself becoming too charged or simply dirty and not the cartridge. Servicing laser printers is tricky business because they use a lot of wattage/voltage to create the static charge and also "bake" the image onto the paper. A very quick fix would be to de-ionize the drum and clean it thoroughly.
First, make sure you have the unit completely unplugged for, at least, ten to fifteen minutes before proceeding to ensure that all static charge has had a chance to dissopate.
Second, remove the toner cartridge and place it on some newspaper or paper towels. Inspect it for any residual toner and/or damage that may be causing the ghosting (look for cracks/grooves/lines in the cartridge that shouldn't be there).
Third, take a used dryer sheet (or one that's had most of the chemical fabric softener rinsed off and then completely dried) and wipe the entire drum to completely remove any static charge. Then, using denatured alcohol and static-free, lint-free wipes clean the entire drum to remove any remaining detritus. Allow to dry thoroughly before proceeding.
Last, wipe the drum down, one final time, with a clean dryer sheet or lint-free cloth. Reassemble the unit and replace the toner cartridge.
Run a few clean sheets (blank prints or copies) to further remove any particles knocked loose and check for any more "ghosting."
Final printing will be necessary to check for inconsistencies or success.
Posted on Nov 08, 2007
SOURCE: Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Posted on Jul 17, 2008
SOURCE: problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Posted on Feb 10, 2009
  • 85 Answers
SOURCE: laser scanner on dell 5110cn laser printer, prints black smudges
replace fuser. How far apart is the ghost image?
Posted on Feb 16, 2009
SOURCE: Black toner spots appear on print outs
You have something stuck on your drum. See page 125 of your manual to clean it--it's just isopropyl alcohol on a Q-tip, but don't scrub. This happens (too) often to some people I know.
Posted on May 04, 2009
Clean pc kit dell 2350dn
Try removing toner cartridge, slowly rock it back and forth and reinsert it.You might get lucky printing.
Jan 12, 2014 | Dell 2350dn Laser Printer
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
I get blotches on my printouts on my Brother HL5270. I have tried "cleaning sheets" and also tried the toner and drum from another Brother printer which prints OK - still get the blotches, so...
First, the print head may be getting clogged and you need toremove the print head and soak (a couple of hours) it in warm distilled waterto dissolve the dried ink. Blot the print head dry with a lint free cloth beingcareful not to rub the electronics. Second, the new ink cartridges (if they arenot OEM) could be causing a problem. Reloaded or second party cartridges maynot always match the specifications for quality required by the printermanufacturer and may accelerate "gumming of the print head". Anotherpossibility of this problemis toner leak. Check if your toner leaks in the rubber filter and cause it to fall and the quality of your prints badly. Hope this willhelp you. Good Luck.
Aug 01, 2011 | Brother HL-5270DN Laser Printer
When printing, I am getting random black spots on my paper.
there is the problem in your toner cartridge. toner drum should be replaced. and the printer also needs proper service.
Oct 13, 2009 | Brother HL 5140 Laser Printer
4250tn print black spot
You either have a bad spot on the drum or a bad spot on the fuser rollers. Replace the cartridge first. If spot continues, take cartridge out and get inside with a flashlight. You'll probably find a piece of paper stuck to a roller.
Apr 04, 2009 | HP LaserJet 4250n Printer
Red spot, Yellow Spot, Blue scratch on the printing document
Hi hope you fine.
is it just a spot or a continous line kind of?
is just a spot check the service kit on the front door (ETB ) alighnment might be touching the prnt drum units.
Sep 21, 2008 | HP Color LaserJet 2600n Printer
Streaks on color copie
You must pull 2 sided glossy from the stack bypass and set on color paper.
Apr 11, 2008 | Canon CLC 1120 Color Copier
55 people viewed this question
jasbo
jasbo
