Question about Kenmore Sewing Machines
How to repair the reverse on my Kenmore Sewing Machine.
The Machine now only goes in Reverse.
    Master:
  • 359 Answers
Many sewing machines have plastic parts. My guess is if you take the cover off you will find some random chunks of plastic fall out. if you do save them and when you get to the revers switch remove it carefully and make carful not of any springs or cogs it may come in contact with clean the area and look at the pieces (if you have them) and see if you can find damaged parts. The next step is to take a picture with your phone and go to the local sewing machine repair store and try to by the parts. You may have to settle for used but in my case the used parts I found were better then the original. If the parts are easy to remove take the parts with you so you can match them up, When you put them pack together you will probably need some kind of grease you can get white lithium grease from the auto parts store, I buy the can, but thats enough grease to last a life time.
Best of luck
'RR
Posted on May 15, 2014
RickE1
  • 202 Answers
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Posted on Nov 25, 2007
  • 12 Answers
SOURCE: Kenmore 385 sewing machine gets stuck in reverse
Make sure that your machine is set to sew forward. The reverse button on your machine should have a spring loaded return. If the spring is in place, and doesn't appear stretched, try a drop (just a drop) of sewing machine oil. Please use sewing machine oil. Not WD-40, or any other household oil. If the machine hasn't been serviced in a while, or used alot recently, they knob may need to be "reminded" that its supposed to go in and out. :) After applying the oil, push the knob in and pop it back out like you have been. If nothing else is wrong, it should loosen up and move freely.
Posted on Dec 04, 2007
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
SOURCE: Husqvarna Viking Sewing Machine 6020 sews in reverse
Take it in to be serviced by authorized Viking repairperson. I understand that for ~ $175 they will disassemble your machine, remove all the hardened grease from gears, calibrate the gears & set tension correctly, etc. A small cost considering these older mechanical sewing machines are GEMS and will provide you another 60 years of sewing bliss if taken care of properly.
Posted on Jan 24, 2010
Sewtech1
  • 69 Answers
SOURCE: Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Posted on Jan 26, 2010
Kenmore 385.1500 sews only in reverse. it is stuck in reverse sewing.
The reverse mechanism lube us going bad. It is accessed from under the machine under the free arm. Usually indicates that the machine is due for a service and oiling. It shouldn't be a problem to get it done at a good sewing machine dealer/store.
Nov 15, 2016 | Kenmore Sewing Machines
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Dec 28, 2015 | Sewing Machines
My kenmore sewing machine is stuck in the reverse mode
The feed assembly is starting to seize. You will have to take it in to be serviced
Jan 04, 2015 | Kenmore Sewing Machines
Will not sew. When attempting to, it moves in reverse without setting it in reverse.
If you have had this machine for long time the problem is most likely the reverse mechanism is stuck. On a lot of kenmore machines the reverse is a spring loaded lob that slides side to side on the lower shaft. Over time the lube that was used dries out and turns pasty. The spring can no longer push the lob and the machine stops reversing properly. It needs to be cleaned and relubed. Best bet is a sewing machine shop with a good repair person. If it is a new machine it could be something else.
Sep 16, 2013 | Kenmore 16622 Mechanical Sewing Machine
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Will not or will?
Computerized machines need to be repaired by a repair person who is certified to work on the brand in question.
Mar 04, 2010 | Kenmore 851S Computerized Sewing Machine
Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Oct 06, 2009 | Kenmore 16622 Mechanical Sewing Machine
Kenmore 15516 It only goes reverse both ways.
Does it have an automatic buttonhole? If so, is the pattern selector set on part of the buttonhole? set it to straight stitch or Zig Zag
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Machine will only sew in reverse
Hi
Questions.
Does the machine only feed in reverse?
Will the machine feed as normal(forward).
If the machine will only work in reverse, then it is highly likely it is stuck in reverse and needs a good service to free it off.
It is very difficult trying to diagnose the problem without looking at the machine. A reasonable sewing machine tech should be able to sort the problem in no time at all.
Rob
Mar 27, 2008 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
