Question about Brother MFC 8500 All-In-One Laser Printer
Same problem even with new Brother drum
Bought new drum and still having problem Error message says to use corona wire...but still a problem. Please help.
  • 390 Answers
Hi
i think its the internal corona wire that has a problem and not the Drum. please check the corona wire a small thin plate like attachment with a wire attached all the way adjuscent to the drum
cheers
Posted on Jun 23, 2009
    President:
  • 2,306 Answers
Did you replace the drum or the toner cart? The drum has a blue lever that you slide back and forth around 20 times to clean the corona wire. I sometimes use a cotton swab with alcohol to gently clean this wire as well.
Why does my Brother HL 3070CW keeps saying "drum error, clean corona wire on drum". I have cleaned all the corona wires, but still getting the same message.
You have to replace your drum with a new one. It has been worn out and cannot keep the primary charge, resulting poor image quality
Jun 13, 2014 | Office Equipment & Supplies
I got a "drum error"
Its been a while since i have done a brother drum change but if i remember correctly dont you have to have the drum front cover open while pressing the clear/back button? Then i think it says new drum/ and you press yes?
Jun 03, 2011 | Brother MFC 7840W Printer
Corona cleaning does not solve error message
You will need to replace the drum unit on the printer.
May 13, 2010 | Brother HL-2040 Laser Printer
Brother DCP 7020 display reads "Drum Error" and instructs me to clean corona wire which I did. I then bought a new drum and still get the same message.
You need to reset after a new drum, open the front door and press menu or options and it will ask if it's a new drum. after that if you still have the error, you may need a new power supply PCB.
Dec 29, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Newly set-up Brother color laser printer displays drum error.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
Aug 21, 2009 | Brother DCP-9040CN Laser Printer
Drum error
Yes, you should replace the drum unit if you have not done so. You may have a broken corona wire or drum. However, keep in mind that you will need to reset your machine after changing the drum unit. If after replacing, you still get the same error, you may have a problem with your machine properly sensing your drum unit.
Jan 03, 2009 | Brother IntelliFax-2820 Laser Fax
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Pls Clean Drum
The drum is the larger plastic unit that slides out an the toner cartridge fits into it. The corona wire is the very fine wire at the front top of the drum. Just slide the little cleaning tab back and forth.
Aug 03, 2008 | Brother MFC-8440 All-In-One Laser Printer
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC 8500 All-In-One Laser Printer Logo
829 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
