Question about Whirlpool WTW5300SQ Top Load Washer
What makes the tub smells after final drain? - Whirlpool WTW5300SQ Top Load Washer
    Master:
  • 359 Answers
That depends, have you left cloths in it wet for an extended period of time? If so it could be bacteria selecting a large load and placing the temperature on hot and adding bleach to the water should fix this. If it smells like sewer gas this could be because there is the trap seal in the "P" trap has no water in it. This could happen if the trap is not vented properly. In other words a plumbing problem. try poring some water in to the trap slowly after the machine stopes if you can get to it.
Best of luck
'RR
Posted on May 15, 2014
My dryer really smells and is making my washing smell reall stale
Check the inside for wearing of plastics or dirt accumulated on the TUB. use some vinegar to wash the tub and clearr off using detergent.
if the smell persists you must check inside for dirt accumulation in the drain or the inner tub.
May 16, 2011 | Dryers
Tip
Mildew smell, gray streaks, won't drain, puddles on floor, burnt motor smell
I have had various issues with my fisher paykel top loader (GWL10US) and didn't realize they were all due to a plugged drain. I had mildew smell from excess water that never drained, gray streaks on clothes from dirt and residue that remained in tub, water left in tub and wet clothes after spin cycle, puddles on floor, and finally it wouldn't drain at all and the motor smelled hot/burned out.
This was all caused by a sock that got in between the outer/inner tub and went to the lowest part of the drain and finally blocked things so a leak was created and water dripped into the motor and caused a burn out.
To repair, bail water out of washer and unplug the washer. Tip machine back so you can see the motor/white plastic housing unit (pump) on bottom of washer. Where this unit attaches to the bottom of the washer, look for a clip/tab that you can pull with your finger (like a childproof cap) and twist the unit off the machine and unplug the connectors (there are 2). Once this unit is removed, you will see a quarter-sized hole into the bottom of the wash tub. this is where i found the elusive SOCK and pulled it through the hole.
When you order the "pump" it comes as one unit--motor and white plastic--and you twist it back onto the machine and plug in the connectors.
another website I've found helpful is ths.gardenweb.com/forum/laundry
on Oct 21, 2008 | Fisher and Paykel IWL12 Top Load Washer
It doesn't drain out the water. Doesn't go through the cycle
hello,
  • Check the draining system for clogs and kinks. First, check the draining hose in back of the washing machine. In Whirlpool models, this hose easily becomes kinked and can block the flow of water. Check the lint filter for clogs. Finally, check the side-check valve, which is located at the tub outlet.
  • 2 Run the washer through a cycle with nothing in the tub. One of the common symptoms of a jammed Whirlpool motor is a nonrotating tub and a burned smell. The belt that powers the pump produces the smell. When the pump gets jammed, the belt begins to split off, causing friction and the burned smell. If you have these symptoms and find a damaged or broken belt, always replace the pump along with the belt. Otherwise, you will damage a new belt instead of fixing the problem.
  • 3 Check for objects in the drain tubes and pump. To get to the pump and hoses, manually drain the tub and unscrew the back panel. Detach the hoses with a wrench and feel inside them for debris. If you cannot find anything in the hoses, feel inside the pump inlets and outlets with piers and remove any debris
  • thanks
    Oct 23, 2010 | Dishwashers
    Smells grey sludge on clothes
    its from all the old detergents not getting to the drain and lay in the outer wash tub,the smell is from mold starting to form in this gooey mess,you may need to remove the inner tub to get this goo out of the outer tub,then make sure the drain pump,hoses are also clean of this goop and there are no kinks,or blockages in the drain hoses or pump
    Apr 29, 2010 | Bosch Washing Machines
    I have an Eljer jet bathtub with a smell to the water when we bat
    What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
    Aug 02, 2009 | Home
    Dishwasher has terrible smell and water lays inside tub.
    The drain is plugged. You will have to pull out the dishwasher and clean out the drain port. A repair person could also do this for the price of a house call. The smell is coming from the dirty water in the tub. You'll have to bail this out before making the repair.
    Jun 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
    Water after spin cycle
    remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
    Nov 05, 2008 | Kenmore 24902 Top Load Washer
    Mildew smell
    water may not be draining completely out cause something is stuck in drainage area.
    Other posts tell how to remove the top of washer to look between white outer tub and inner wash tub for sock or something else that is lodged.
    Look at my post on "eco smart won't drain, smells hot" for instructions on removing the black motor/white plastic housing from bottom of washer. I had a sock stuck in the very lowest part of the drainage system, water wouldn't drain out and couldn't see the sock until I removed the motor. I was able to pull the sock through the quarter-sized hole in bottom of tub and drain the remaining very stinky water. I used a dog dish (need a low edge bowl to fit under washer), tipped washer forward, then back and just kept emptying the dish.
    Saw another post said don't tip washer back. There is something on backside of washer that you could break if you tip backwards. So, if you tip forward i guess you won't break anything--i haven't...yet.
    Noticed a musty smell lately, and also had gray streaks on my clothes. Think the standing water that wouldnt' drain out has been my issue for some time now and when the motor burned out, I finally had to research the other issues.
    Sep 20, 2008 | Fisher Paykel EcoSmart GWL15
    Admiral Washer smells like mildew
    yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
    Lower the drain if possible
    Apr 10, 2008 | Admiral AW22 Top Load Washer
    Foul odor
    Run the washer on the hottest setting you have with nothing but a cup of bleach in the tub. Pour the bleach through the dispenser so it cleans the dispenser as well. Run the washer like this and let it complete the cycle. If the smell persists, remove the lower kick panel under the door and check the drain trap on the drain pump for anything that could be caught in the pump and making it smell. This odor can travel back into the the wash tub. If you decide to open the drain pump, however, here\'s a bit of advice. There is some residual water that stays in the drain lines and pump (this is normal). If you remove the drain trap cover, all this water will come gushing out. To avoid this, take the drain hose out of the standpipe and use a wet/dry shop vac to pull this remaining water from the tub and lines. This will save you from a big clean up later. Lastly, you mentioned you\'ve been cleaning the rubber door boot. Are you using 50/50 mix of bleach water in a spray bottle? Are you cleaning the area behind the door boot where it meets the wash tub? I ask this because once mildew sets into the rubber it\'s hard to get rid of it unless you use something with chlorine in it to kill it. Also, articles of clothing get caught in this area and can begin to smell. Not to mention, all the nasty residue left by soap and detergent. If all else fails, and you have tried all the advice, the last thing I have found that works, is to simply replace the entire door boot. Try the cleaning options first, and if you still have problems let me know. I can give you step-by-step advice on how to change the door boot if you wish to pursue it. The cost, by the way, is about $80. I hope this helps you.
    Sep 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool WTW5300SQ Top Load Washer Logo
    22 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
