Question about Pride Celebrity Xl 4 Wheel Scooter
My scooter xl-8 3:1 - Pride Celebrity Xl 4 Wheel Scooter
How to fixed my scooter all arroun
go google and type in ---workshop manual for pride legend xl scooter --and if there is a pdf version , download it
if not contact the manufacturer direct and see if you can buy one
Aug 16, 2016 | Pride Health & Beauty
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
Jun 03, 2014 | Pride New Mobility Victory XL 4 Wheel...
Is it possible to get a copy of the repair manual for a 3 wheel Pride Legend XL scooter?
hi, it not a repair manual but a owners manual that is very helpful, the XL is my own personal favourite scooter but suffered from dodgy wiring and connectors otherwise it's a blast, I have reprogrammed the eGis controller to hit the max speed 10 mph.
Regards
GeWiz.
Mar 03, 2013 | Pride Health & Beauty
Pride Pursuit XL scooter won't charge
Is this the Pride Colt XL 8 scooter ? if so look at the steering column, there is a fuse here for the charger ?
Please give feedback.
Dec 19, 2012 | Pride Mobility Pride Pursuit XL 4 Wheel...
Set to move at 8 mph on full charge speed set to max only moving at 1 mph or less using battery charge in 20 mins
Hi, Sadly that sounds like your batteries have called it a day however please check your charger as this can have a fault and this can make your batteries appear weak and the battery teminal connections, are they loose ?. Check your manual as I think you can fit 12V 40Amp batteries to this scooter.
Please leave feedback if my advice helps.
Jan 17, 2011 | Pride New Mobility Victory XL 4 Wheel...
How do i get the manuals that came with the scooter.
Here is a website from Pride mobility that will allow you to download a PDF version of the owner's manual for your scooter. Copy this link into your web browser and press enter, then scroll down the page to the Scooter section and you will see the Victory XL-4 listed. Click on the name and save the file to your computer.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
I hope this information is helpful, good luck!
Dec 31, 2010 | Pride New Mobility Victory XL 4 Wheel...
Could you please tell me where i will get forward& reverse throttle for pride victory
Throttle potentiometers are a frequent part that is replaced on scooters due to wear. This part is available from the manufacturer Pride or from a company called Monsterscooterparts.com.
At the Monsterscooterparts home page click on mobility scooter parts, pride scooters, pride parts click on Pride Victory XL SC270 , select throttle pot assembly. Verify SN and compatibility remarks. They have an 800 phone number for questions and they ship worldwide. The Pride part number is ELEASMB 1511 for Victory XL 4 wheel scooters after the year 2000. Looks like the price is about $80. Labor is about 1/2 hour and can be done by an experienced mechanic or do-it-yourself. The part is available from the manufacturer if you are a dealer or have an account.
First remove the throttle lever by loosening the allen set screws. Separate the front console covers by removing 8 or more screws holding it together. Locate the throttle pot, unplug it and install a new one. Be careful not to over-tighten or strip the screws holding the potentiometer housing tabs to the plastic. Check the alignment visually before reassembling it. Don't pinch any wiring when you put the console back together. When you reinstall the throttle lever make sure it is even left to right and does not bind on the plastic console housing. Tighten the lever set screws firmly but do not strip them, this repair will need to be done again and you want to be able to remove these set screws. Hope this helps.
Nov 07, 2010 | Pride New Mobility Victory XL 4 Wheel...
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Feb 07, 2009 | Pride New Mobility Victory XL 4 Wheel...
Pride Celebrity Xl 4 Wheel Scooter Logo
35 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
