Question about Konica Minolta Office Equipment & Supplies
Error 04 how to clean wires
  • Konica Minolta Master
  • 6,168 Answers
What wires what model
Posted on Jul 17, 2014
Error SC21-04
If you mean the circuit and inkjet holes on the gold coloured strip then just use a soft cloth or tissue and wipe over the print head on the bottom of the cartridge, when you fit it into your printer its best do an alignment and print a test page too. Hope this helps!
May 15, 2014 | Konica Minolta Office Equipment & Supplies
Tip
Error code CH-04
In LG multi split/cassette type units, error code ch-04 means Float switch Open circuit (High level water alarm). Dis assemble the indoor and clean drain pan.
on Jan 11, 2011 | Heating & Cooling
Konica Minolta
Located above the drum is a assy. that place a HV charge on the drum before the LASER places the image on it. That HV wire has cleaning pad that is run by a motor to clean it. that code deals with that need to remove the drum cart and check if it is jammed or the motor is burned out worse case the board controlling it is bad $$$$$$$$$$$$$. Have tech look at it and prevent its use just nice to have
May 15, 2014 | Konica Minolta Minolta Dialta Di850 Toner...
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
I have error 04 on SONY CDX-R3000 player
Hi
Error 04 is a CD Problem its either need to be clean or CD inserted upside down
if there is no media inside try to clean with a cd cleaner it should help unless the laser unit is not good
ecrdn@yahoo.com
Jack
Nov 04, 2010 | Sony CDX-R3000 CD Player
SONY CDX 5090 - E 04 error message.
I have a Sony cdx 5090 car stereo, I don't have the manual for it. I need to know the wiring color codes for it to hook it up.
Aug 22, 2009 | Sony CDX-5090 CD Changer
My computer crashed so I bought a recovery disk from tech guys, trying to do a full distructive recovery i get an error code 04 how can i fix i Advent 7113 laptop computer
Hi there.
Error code 04 means that the CD cannot be read properly, take the CD out and make sure its clean, also get a CD/DVD lens cleaner and clean the lens on the CD drive.
Please post back if you need any more help.
Good luck and thanks for using FixYa!!
May 11, 2009 | Computers & Internet
KM Bizhub Pro 920 gets an error: SC21-04.
Wire cleaning problem, there are several motors in the copier that have the job of cleaning Very HighVoltage Drum Charge Wires and Image Transfer and seperation High Voltage wire The wires have a corona (Not beer:)) form on them and need to be cleaned.
Mar 25, 2009 | Konica Minolta Office Equipment & Supplies
Error "04" on display & tape won't eject
you have bad capacitors in your power supply. i would suggest you take your unit to a good shop in your area and request a power supply re-build and mode switch cleaning.
Jan 22, 2007 | JVC BR-S822DXU VHS/S-VHS playback VCR
32 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
