Question about Konica Minolta Office Equipment & Supplies
Error SC21-04 HOW TO CLEAN THE WIRES
    Problem Solver:
  • 14 Answers
If you mean the circuit and inkjet holes on the gold coloured strip then just use a soft cloth or tissue and wipe over the print head on the bottom of the cartridge, when you fit it into your printer its best do an alignment and print a test page too. Hope this helps!
Posted on May 15, 2014
Testimonial: "cleaning konika minolata wires"
  • Steve Bielby May 15, 2014
    Sorry but I don't understand your question, which wires? what do the wires do? where are they on the printer?
What is error e7?
This error means 2 alternatives : a) elevation motor NOT working + b) display not working too.
However you are mention that after 3 seconds the machine goes stop.This reveal that you must to do the following:
1) LUBE the deck belt very well, lack of maintenance shut down the machine for protection.
2) LUBE the rollers bearing,too
3) test the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are not the board is faulty.
see the block diagram
1) alternative for error codeLa) elevation motor LUBE the gear and shafft and adjus the pot.,tight any wires connector and clean
2) alternative for error code 7 b) adjust the REED switch, clean and tight the wires connector very well. see the block diagram
after you fix RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you
7_17_2012_10_13_08_am.jpg7_17_2012_10_13_31_am.jpg7_17_2012_10_14_05_am.gif7_17_2012_10_14_22_am.gif
Jul 17, 2012 | Tunturi T30 Treadmill
I have star trac pro treadmill,when i shifted from another place it show the error
1) Run the software calibration for diagnose, troubleshooting.
2) However adjust the reed switch, clean, and tight any wires connector see the diagram
3) adjust the speed sensor, clean, and tigh the wires connector see the diagram attached.
Jul 06, 2012 | Startrac Fitness Products Star Trac Pro S...
Error code
1) this error indicate pump relais defective,repair the relais clean the contact,or wires associates in board.
2) Otherwise you must replace the board, call to the customer service and do it.
God bless you
Jun 19, 2012 | Washing Machines
Error 541 and 300
Thank you for contacting FixYa with your printer error.
Error 541: Take the fuser out and clean under the thermistors, and reset the code by entering test mode ( turn off printer hold down online and escape as you turn on printer select 2 engine go to sp5-810 and reset this.
Error 541: (Option 2)While the printer is on do the following:
  1. Hold down both of the arrow keys for 10 seconds
  2. Press ENTER
  3. Select Option 2 for Engine
  4. Choose 7 Data Log
  5. scroll down to 7807 and execute it. click OK
  6. press the escape button until you get to the engine option
  7. then select option 3 to end
  8. restart the printer by pressing the power button.
Error 300: t's a charge error and can be related to the corona itself shorting, the power pack or the toner door switch...and possibly the NVRAM. Replace your main charge wire , and clean and or replace grid wires also ( 4 grid wires )
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 11, 2011 | Office Equipment & Supplies
WL80T65C - error 245, can you please advise on this error?
The error 245 is a drain pump stall. Take the pump out from the bottom of the machine (2 screws) and clean it out. The resistance between the red and blue, blue and white, and red and white wires should be 16 ohms, if not, replace the pump.If the resistance is ok then clean the drain pump and drain hose to which the pump is connected.Clean it with normal tap water.Then refit it and check.In most of the cases cleaning the pump and hose helps.In some cases the pump has to be replaced/.----------- This will help.Thanks.Helpmech.
Jan 20, 2011 | Fisher and Paykel Washing Machines
Won't self clean. I am getting an error messag FSE 1.
Most likely it is F5-E1 code. self clean latch will not lock. follow procdures below,but likely problem is failed lock motor
All F5-E Codes - Door Switch Defect - This occurs when the door switches do not match. If door is latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, reconnect power and hold down any key until the F5 error clears. Once the F2 code appears, select 'cancel' and observe for one minute for errors. If door is NOT latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, measure door switch (door open = latch open) and latch switch (unlatch = switch open) and replace either if defective. If corrections are made during any step, power should be reconnected and the unit should be tested. Press and hold any key to clear the error code and F2 code should appear. Select 'cancel' and observe for one minute for errors. If error continues, disconnect power and replace control.
Dec 28, 2010 | Whirlpool GR460 Electric Kitchen Range
Whirlpool RF375, door error when using oven
FWIW I got the same problem after removing insulation on the top ot the oven to deal with rodent fecum/urine headache on RF375PXDW model. There is a microswitch with 2 black wires and 2 white wires related to the lever for the "clean" function. I noted that the 2 smaller guage white wires were stuck together, I seperated them, door error issue went away. Replaced the wires with new homemade, seperate looms. They were obviously melted together, causing a short in the circuit.
May 10, 2010 | Ovens
IR5000 bloque
this is a code for detection of no or faulty charge to the drum open front door remove toner hopper take out primary charge unit see if any wires are broke on grid , then see if the wires underneath the grid are still there... if all seems ok gently clean the grid with cloth and windex then clean wires underneath dont break grid wires . put it back in let me know
Dec 23, 2008 | Canon imageRUNNER 8500 Copier
Kyocera fs8000c
Clean separation charger wires, or replace separation charger wires or unit. This code says that there is separation voltage leak..
Nov 02, 2007 | Office Equipment & Supplies
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
