Question about Samsung DV350AGP Gas Dryers
Samsung gas dryer dv350agp/xxa have lights come on but is not working
Display shows its working but drum not spinning
    Master:
  • 379 Answers
It could be that you have a broken belt. Can you heat a motor running? Try placing your ear to it when you turn it on, if you can hear the motor running then remove the back panel and see if the belt is in tacit.
Best of Luck
'RR
Posted on May 15, 2014
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Drying time goes from 44 to 6 minutes
Check your vent system first to make sure that it is clean. You most likely have a bad thermistor in the dryer. The thermistor senses heat and humidity and is responsible for telling your dryer when to shut off. It is probably reading out of spec
Feb 07, 2014 | Samsung DV350AGP 7.3 cu. ft. Steam Gas...
Samsung gas dryer dv331 will power up but won't run. The lights blink and the unit clicks one but won't start.
Try spinning the drum by hand. If it's really loose, then you need a new belt. I recommend getting this done by a professional, or you watch a youtube video. It takes a standard whirlpool belt.
Nov 03, 2013 | Samsung DV331AER Dryers
Any recalls on aluminum dryer drums from samsung? less than 2 years old and seam split
No recalls. Warranty is one year on parts and labor. New drum is 124 dollars.
Aug 07, 2013 | Samsung DV350AGP Gas Dryers
High pitched squeaking dryer
its just the bearing and it needs replaced. it will take about two hours to do and it will cost you about 30 dollars in parts. you can find many really goods vids on youtube that will show you how to do it and most parts manufactures now have directions on how to do it in the cluded when you buy the parts.
May 09, 2013 | Dryers
We were turning our drum and heard a loud pop sound; plus the clothes hadn't gotten dry.. the lights and everthing shows up but the dryer won't start up now
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'';
Jun 13, 2011 | Samsung Dryers
GE Profile gas dryer, DPXB515, no heat and no drum spin
the humimg you hear is from the motor,check the blower wheel that is below the lint filter,if a sock or something gets sucked into the blower the motor can't spin,check the belt,if it is jamed the motor can't spin,if these things check good you have a bad motor
Nov 05, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Samsung DV350AGP Gas Dryers Logo
61 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
