Question about Whirlpool Refrigerators
Freezer not freezing
I have a Whirlpool WRF990SLAM00 side by side, and the freezer has quit working. The ice dispenser which is located in the fridge part was not producing ice and what ice was in the bucket was melted. I turned the temperature down to see if that it helped and as of this morning it is still not cold enough to freeze a bottle of water. Of course, my warranty expired one month to the date of this problem. Freezer and ice dispenser were working fine that day; however, that night we had a huge storm with lightning blow through. Any suggestions would be appreciated....
  • 1 more comment
  • Raymond Richards
    Raymond Richards May 16, 2014
    You can also have a whole house surge protector install in your barker panel by a qualified electrician.
  • W.L. May 17, 2014
    They have a dog installed?!
  • Raymond Richards
    Raymond Richards May 29, 2014
    Congratulations, I am very happy for you. I hope your new fridge is trouble free. Best of Luck
  • 2,509 Answers
It might be worth contacting where you purchased as it is so close to warranty, but I don't think it will help to mention the lightning!
If it needs (for example) a control board (a possible cause but it might be something much simpler) these are upwards of 120 dollars.
If you are prone to storms you should consider running your sensitive appliances (anything with delicate electronics) from surge protected extension sockets.
Your post implies that it is getting cold but . not cold enough to freeze?
One other thing to try is to disconnect it leave for 15 min and reconnect. good luck, let us know how you get on
Posted on May 15, 2014
Testimonial: "Thank you for your response. I tried this a couple of times, and unfortunately it didn't work. Whirlpool has agreed to repair it even though the warranty has expired."
    Master:
  • 379 Answers
Sorry about the lightning storm that could be related. If the fridge side is still working then the compressor is still working that is the good news for the freezer to work you need a fan. The next thing to do is open the freezer door and hold the switch so the freezer thinks the door is closed. There should be a fan running. if the fan is running and blowing hot air. you will need a tech. If you do not hear a fan then start removing shelves and then the covers at the back wall of the freezer. when you find the fan you will need a tester to see if it has power. if it has power but will not turn replace it. Removing the covers will also give you a chance to see if the coils are cold. if they are good if they are hot not good. By coils I am talking about the ones inside not the ones out side (which need to be cleaned once a year).
Best of luck
'RR
  • Michelle
    Michelle May 29, 2014
    Thank you for responding. I'm sorry that it hasn't taken me so long to respond back. Long story short....Whirlpool is replacing my fridge because they have been having issues with this model and it is cheaper to replace it than to repair it.
  • Enrique A vila
    Enrique A vila Sep 19, 2017
    I have the same issue with no warranty and also I am in mx can somebody knows what is the problem with this model?
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
icansurf
  • 72 Answers
SOURCE: The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Posted on Jul 11, 2007
dididsaythat
  • 291 Answers
SOURCE: Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Posted on Sep 08, 2007
freetek
  • 5568 Answers
SOURCE: Candy Fridge - The freezer part is not cold enough, fridge ok!
A couple of things to check-
- Is the condensor cooling fan running? This will be located to push air through the external cooling coils, wherever they are located.
- Does the auto-defrost timer work? It may have failed and stayed in a position that has left the heating elements (for defrosting) turned on.
- Does it seem to be running way too long and not turning off as it once did? This could indicate either a loss of coolant (would need recharge and leak detection) or the compressor is reaching its end of life. If the latter is the problem, expect a cost of $200-$400 US.
Posted on Apr 07, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
Whirlpool fridge freezer
The fridge side is cooled by the freezer side. Try unplugging power, open freezer door and let thaw out/defrost.
Apr 30, 2014 | Refrigerators
Freezer is working fridge is not
Hello Carmenbonds,
I understand that you are having a problem with your refrigerator not working, the freezer side is working but the fridge side is not cooling. This is a common problem that happens when your evaperator fan is not working. I have wrote a tip that will help you with this here is a link to it.
Freezer freezing but Fridge is Hot.
Thank you for choosing FixYa.com
Justin
May 10, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge is not cooling
Hi; Is the Freezer still Freezing? If it is you may find Either fan motor or the vent that supplies air from freezer to fridge is't work (CLOSED) this is located in the wall that seperates frz/frd you may beed a mirror to check this. This may need a screw put in to keep it open slightly.
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a side by side fridge freezer. The fridge compartment is freezing the food. can you help?
check thermostat for loose or damage connection but check the damper/blend door -located -in freezer where the fan is located and in the fridge where the air blows in is a duct and inside the duct is a damper -door that opens to let in cold air from freezer and closes when the fridge reaches temp some times ice or a piece of debris restricts it from fully closing or the unit gets stuck open--
Nov 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Mar 31, 2008 | Refrigerators
Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Aug 27, 2007 | Refrigerators
Refrigerators Logo
1,075 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
