Question about Daewoo Refrigerators
Replace daewoo Dff 470SW fridge freezer lamp
Lamp no longer works. needs replacing with 15W SES Pygmy lamp
    New Friend:
  • 8 Answers
Here is a link seems like all in the UK Daewoo DFF470SW Fridge Freezer Lamp
Posted on May 17, 2014
Which terminals do you bridge on the 12 pin plug for a Daewoo Nubira 2000 to extract the fault codes?
Pin
Number Pin
Name Description (may be empty) A GND Chassis Ground B L-Line Engine diagnostic, ABS (8KBaud Serial Data, not always present) C AIR may be n/a D SES-LAMP Self-diagnostic lamp (may be not available) E K-Line K diagnostic line (160-Baud Serial Data) F TCC may be not available or +12V G fuel pump control (may be n/a) J K-Line Airbag diagnostic (8KBaud Serial Data) M K-Line Engine, ABS diagnostic for all models produced until 2000's
A. +7.35v permanently and +12V when ignition is on.
B. Empty
F. +12V permanently
G. Empty
H. Empty
J. Empty
L. +12V when ignition is on.
M. -12V (GND) Daewoo 12 pin diagnostic interface pinout
Mar 28, 2018 | Daewoo Cars & Trucks
My swan sr5140w keeps blowing new bulbs as soon as power is turned on
Check the voltage of the bulb. It is only an SES 15W mains powered lamp.
Aug 07, 2017 | Cars & Trucks
How to fix .
post symptoms like this.
i check head lights, they work key out , so do they?
i turn the key to Ignition on.
the dash self test lamps all glow, do they,?
look at that CEL lamp, (aka SES) lamp, check engine lamp
it it dont glow the engine brain, lost power, fuse, (head lamps work)
if the CEL glows. then now crank the engine, (start pos.)
does it crank robustly? yes /no?
yes, do you have spark>
no, does car crank over fast with jumper cables to running donor car?
that is start, no pun.
Jul 18, 2014 | 1999 Saturn SL
How does one replace a Daewoo Dff 470SW Fridge Freezer bulb
Not sure on your actual model but normally the opaque cover slips off and then the bulb just unscrews, have a look at the cover and try to work out if it slides back into the compartment or forward towards the door. On some which are a U shaped cover, you have to squeeze the sides towards each other and pull away from the wall of the compartment. Hope this helps!
May 15, 2014 | Computers & Internet
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
Conia CF 360 Hi my Conia Fridge light bulb has blown and I gave it to a friend to find me a replacement - He has now lost the original bulb and I am having trouble getting a replacement that fits...
Hi
Most electrical suppliers will have a bulb to fit, they are normally a screw fitting, you will probably need, write this exactly
15w SES lamp
It means 15 watt (lamp power) Small Edison Screw, odd times they have used a
15w MES means the same except Mini Edison Screw
Regards
Gordon
Apr 20, 2011 | Refrigerators
How do change the ref bulb on sharp ref model sj p43n - sl
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
Feb 25, 2011 | Refrigerators
My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 26, 2009 | Daewoo Refrigerators
Replacement lamp for hotpoint RLAV21 fridge
hello, it is preffered to put a 10w or a 15w in anything less will blow as soon as u put it on.
Feb 05, 2009 | Hotpoint RLA21W Compact Refrigerator
Refrigerators Logo
176 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
