Question about Frigidaire FTF530FS Front Load Washer
Ftf530es knocks during spin cycle
Drum moves from front to back not up & down
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Amy,
I understand that your Frigidaire washer, model# FTF530ES, knocks during the spin cycle. I also see that the drum moves from front to back and not up and down. I suggest making sure that your washer is level from front to back, side to side, and from corner to corner. If after leveling you washer, the drum is still moving from front to back, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why the drum is moving from front to back. Hope this is helpful.
-Best Regards-
WP
Posted on May 15, 2014
localwonder
  • 6784 Answers
SOURCE: Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Posted on Jun 15, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
njvinod
  • 1462 Answers
SOURCE: Frididaire ftfb4000fs1. Washer. Will not spin
IT IS THE ISSUE WITH THE DOOR LOCK ASSEMBLY, COST AROUND $50.00 WHICH IS FAR BETTER THAN $300.00, WHAT A SERVICE REPAIR PERSON WILL CHARGE YOU. YEA IT'S THE CRAZIEST THING IMAGINABLE,
THE DOOR LOCK ASSEMBLY BEING THE CAUSE FOR IT TO NOT SPIN ALL THE WATER OUT. YOU CAN FIX IT YOURSELF, HAD TO TAKE IT ALL APART VERY CAREFULLY,
YOU CAN GET THE PART ONLINE OR GO TO NEAREST APPLIANCE PARTS STORE IN YOUR CITY. ASK FOR DOOR LOCK ASSEMBLY. THEY WILL KNOW EXACTLY WHAT YOU'RE TALKING ABOUT BECAUSE IT IS A VERY COMMON, I REPEAT VERY COMMON PROBLEM WITH THIS BRAND OF WASHING MACHINE
Please leave me comment, if you need further assistance
Thanks for using Fixya
Please rate this solution
Rnj VinodKumar
Posted on Dec 15, 2009
Testimonial: "I would have never guessed that one. You were correct. Thanks. "
SOURCE: the drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Posted on Jan 04, 2010
Washing machine knocking.
Does the drum wobble quite a bit or does it look normal? If it's wobbling it could be the drum casing knocking the internal structure. Might need a new drum spring if this is the case
Oct 20, 2014 | Washing Machines
2001 Gibson Washing Machine - Front Loader
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 29, 2008 | LG WD-12126RD Front Load Washer / Dryer
Good Morning Friend,
I understand that your Frigidaire washer, model# FTF530ES, is having trouble with the drum rocking back and forth, from front to back. I suggest making sure that your washer is level. I would check from front to back, side to side, as well as from corner to corner. If you have leveled your appliance and are still noticing the drum rocking from front to back I would suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FTF530FS Front Load Washer
Knocking in trany during agitate/wash cycle
Probably a bad tranny or bad bearings on the tub.
Mar 12, 2010 | Washing Machines
Kenmore he2plus vibrate very badly, it is level how do i fix this
My HE2T was making a horrendous sound during the spin cycle. It was making a loud clacking sound and the machine was moving all over the place.
There are two things to check. The first is that the feet are on the floor and the machine is level. The second is a bit more complex. Remove the three screws that hold the lower panel. Underneath the drum on each of the four corners are suspension rods. One side is attached to the drum and the other side is bolted to the bottom of the washer. My bolts loosened up which allowed the suspension rods to clack back up and down as the drum spun. You'll need to tighten those bolts very tight and then give it another try.
Attached on the inside of that cover is the troubleshooting guide. There is a manual diagnostic mode and you can step it to the spin cycle so that you can test the spin balance without having to run through a full cycle. Make sure you have some clothes in there during the test.
Jan 09, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet WFW9200SQ has knocking sound located under drum under or near motor. Knocks during spin up and down cycle and on last highest spin.
the problem is a cracked spindle on the back of the drum. It most likely also tore up the grey plastic front shield.The only thing to do is throw the machine out sine the drum cost parts onle is over $400 for drum, and over $400 for the front plastic.l
Nov 12, 2009 | Whirlpool GHW9200L Front Load Washer
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
How to check the water pump on a Frigidaire FTF530ES
you can take the belt off and turn it by hand to see if it is hanging up and moves freely,take hose off to check impeller inside,most of the time if its lound during spin it's the transmission,if it is a humming sound the water pump-mike
Nov 03, 2008 | Frigidaire FTF530ES
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
116 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
