Question about Video Game Consoles & Games
How much is sns 001 worth - Video Game Consoles & Games
    Master:
  • 665 Answers
The super Nintendo system was released in the U.S. in 1991. For the starting price of $199.00. Recently, I've seen them go as cheap as $25. with no games or cords. But starting at $50. with all cords and 2 controllers. The price goes up from there if you add games. I hope this helps.
Posted on Jul 05, 2014
Getting a sns code on control panel display. Where is the sensor located on this pool heater?
In the header... Plumbing side
And wire plugs onto heat / control assembly board.
SNS indicates that the Temperature Sensor is out of range! There are two thermistors within that sensor, and if there is a difference of 2 degrees, the board will throw a Fault Code: SNS
check for good connection at board, and ensure the sensor is all the way seated properly in its well.
otherwise, it may be bad.
Apr 25, 2015 | Rheem M266A 266K BTU Pool or Spa Natural...
Raypak sns code
bad temp sensor
Apr 06, 2012 | Raypak Pool & Spa
RAYPACK POOL HEATER CODE RV1 THEN SNS
check gas pressure and safety circuit then ignitor sns means temp sensor bad
May 31, 2011 | Raypak Free Hydraulic Lift Gate Delivery -...
Display is reading sns. what does this mean?
SNS 1) SENSOR IS FAULTY
2) TEMPERATURE IS ABOVE 110°F
3) TEMPERATURE IS BELOW 36°F
It is one of the above situations
Apr 27, 2011 | Raypak 2100 Pool Heater Gas 336000 BTU'...
I get sns on my heater
SNS on Raypak heaters means the following:
1. Water temp is below 36 degrees F, or above 110 degrees F.
2. The sensor contains 2 thermistors. If they are more than 2 degrees aparts, an SNS failure will occur. Replace sensor.
3. Loose or corroded connection at P1 on the main CPU board (right behind the LCD screen)
4. If the sensor is not mounted ALL THE WAY into the JACO fitting (on top of the header) it will give a false reading.
It is more likely than not, that you need to replace the temperature sensor. Part number 009577F.
Jan 26, 2011 | Raypak Free Hydraulic Lift Gate Delivery -...
Rheem 206 propane heater will not fire has code #sns what is the problem? the water is 65 degree.
SNS means the temp sensor is out of acceptable range. Could be the following:
2. The sensor contains 2 thermistors, if they are more than 2 degrees apart and SNS failure will occur
3.Loose or corroded connection at P1 on the main board
4. If the sensor has come out of the JACO fitting on the header, it may read a SNS failure.
Solution, visually inspect the connections for corrosion. If it looks ok, then replace the temp sensor.
Jan 01, 2011 | Rheem M206A 206K BTU Pool and Spa Propane...
Heater displays SNS - sensor failure. what do i do?
sns occurs when sensor reads temps under 36 degrees or above 110 degrees. check temp of of water to verify.....may need a new water sensor
May 30, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
