Question about Refrigerators
Whirlpool refrigerator et18gkxhw0
How many cu feet is this fridge
  • 378 Answers
SOURCE: Compresor will not kick on. all fans running,
Compressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps  ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example oneexample twoexample three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install areplacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed.
Posted on Apr 03, 2009
alex_salve
  • 78 Answers
SOURCE: Refrigerator/freezer runs but never cycles off...
thermostat relay needs to be replaced
Posted on May 25, 2009
  • 93 Answers
SOURCE: whirlpool refrigerator ET18GKXHW0 NW power cord ripped out
The refrigerator should have a wiring diagram. Look in the grill on the bottom of the front of the refrig. Pull that grill off and a lot of times they are in there. Sometimes thay are taped to tha back also. You can buy a wiring diagram just like any other part from Whirlpool or sears parts center.
Posted on Sep 12, 2009
erpaalai
  • 999 Answers
SOURCE: I was given a Whirlpool ET1FTK 20.8 cu ft
Start at the top and remove the hinge (5/16 socket). Slip the door off and remove the center hinge. Slip the lower door off and remove the lower hinge. Now is the time to reverse the door swing if it needs it. Move the handles to the other side and reassemble with hinges on the other side if you do.
Eric
Posted on Nov 03, 2009
heatman101
  • 43501 Answers
SOURCE: Refrigerator is not cooling but light is on.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
What is the cubic feet of Kenmore refrigerator 253.77872509?
The fourth digit after the prefix usually indicates the refrigerator capacity. It probably has 27 cu. ft. capacity. (If it is a small apartment size fridge would be a 17 cu. ft. model.)
I hope this helps.
May 05, 2017 | Kenmore Refrigerators
I have space for a 64in.height,32 in. width,26 in. depth refrigerator. What size in cubic feet should I get?
Well, these measurements will limit the outside of the cabinet. The size of fridges almost always refers to the inside capacity. The relationship between the two varies a little from model to model. For instance if you get one with an ice maker, the inside capacity is less, but the outside is the same as the same fridge without ice.
You could buy for instance a Whirlpool 14 cu ft top mount freezer model, which is 63" h x 28" w x 26" d. The 18 cu ft is too big. Another possibility is the Frigidaire 14 cu ft.
Nov 13, 2015 | Refrigerators
Need to know how many cubic feet my frig is so I can compare when shopping for another.
This is the information I could find.
Refrigerator Type Side-by-Side Total Capacity Cu. Ft. 21.7 Cu. Ft. Refrigerator Capacity Cu. Ft. 14.40 Cu. Ft. Freezer Capacity Cu. Ft. 7.30 Cu. Ft. Energy StarĀ® Qualified Yes
for more information try this link.
Whirlpool Appliances for the Home Kitchen and Laundry Room
Bob
Mar 16, 2015 | Whirlpool Refrigerators
What are the things to be consider when buying a refrigerator for small family
The capacity in cubic feet.This link shows a 4.8 cu feet fridge, you would probably need something more spacious than this:
http://www.beko.co.uk/ProductDetails.aspx?ProductModelID=294
The energy rating of the fridge. It should cost as little as possible to run.
Whether you want an ice box, if you have a freezer, the ice box is just waste space in the fridge.
The number of shelves and whether they can be spaced to your liking
Whether you should buy a fridge freezer or not.
Mar 04, 2011 | Refrigerators
Whirlpool refrigerator ET18GKXHW0 NW power cord ripped out
Sep 10, 2009 | Refrigerators
heatman101
Jul 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Greetings! My Whirlpool 21 is not cooling on the bottom, but the fridge is OK. Art
I do not understand your question because your note says it is a top freezer, but the fridge is ok?
The bottom section IS the fridge on this type.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
