Question about Memorex MVUC821 8 in. Under Cabinet TV
The red standby light comes on but,when I push the power button,and the unit will not turn on.
3 Suggested Answers
SOURCE: NOTHING WORKS ON DVD PLAYER
My daughters had the same problem, try replacing C411 (I think that was the number on the board), its a 10V 1000uf capacitor in what appears to be the 5V power supply section toward the right rear of the main board, that fixed it. On hers the capacitor was swelled up on the end. I checked it out of the circuit and the DVM I used only indicated it had about 500uf capacity.
Posted on Sep 26, 2007
jdvillanueva
  • 2098 Answers
SOURCE: When I plug the tv
This kind of symptoms indicated of malfunction in the inverter circuitry inside the TV. It gone to overload due to the following reasons.
1. Busted bulb - If one of the bulb was already busted, the inverter gone to overload and the feedback circuitry will turn off the power supply to avoid further damaged. It can't be test by the multimeter but has a physical indication of fault like blackened end.
2. Faulty inverter circuitry - Once this circuitry gone bad same symptoms will be encountered. This was caused by shorted secondary high voltage transformer, driver transistor, open fusible resistor.
The unit must be take apart if not under warranty to check the bulb, and troubleshoot the inverter circuitry to determine where the fault came from.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a professional to isolate the problem.
Also, check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Opening the back cover will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jun 13, 2011
Hitachi l37v01ua won't turn on from standby mode.....HELP!!!!
when in stand-by mode then red light's blinking. Try to turn it on not from remote but by pushing a button on the set.
Apr 26, 2015 | Televison & Video
Preamp stuck in standby mode
a flaslight bulb and batteries and couple of wires can be used to make a continuity tester.and also pls check the small pushbutton(power button)try the remote if theres any
Feb 04, 2014 | Adcom GFP-710 2-Channel Amplifier
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Red light comes on but the shuts off?
Mine did that and it really pised me of, sony told me to turn the power switch onthe back of the console on, when the stand by light comes on to push and hold the on button for at least 3 seconds until you hear a second set of beeps. This however didn`t work so I sent it back to Sony Australia and got it fixed up no worries.
Oct 11, 2008 | Sony Playstation 3 (PS3) Console
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Memorex MVUC821 8 in. Under Cabinet TV Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
