Question about Exercise & Fitness
Where is the shroud on the sole e95 elliptical
4 Suggested Answers
SOURCE: Power ramp does not work.
Ignore everything above - most of the time this is an easy fix. Usually, it happens with a brand new console, or a machine that has reset itself.
Hold down the incline up (on the console itself) button and the start button at the same time. Then follow the instructions on screen.
It will run through an initial calibration, and once complete, the ramp will now work. Just did this with mine, and my ramp is now working perfectly.
Posted on Nov 30, 2011
mendi593
  • 65 Answers
SOURCE: schwinn 450 elliptical not registering pedal movement
You will need to take the front stabalizer off before opening the machine.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
Posted on Jul 17, 2012
  • 46759 Answers
SOURCE: Sole 235 elliptical causes static that interferes with the tv and pvr.
the machine has has front drive system which indicates an electric motor
static can be caused by brushes arcing on the commutator bars
that would require a check by an electrician or technician
removing the rubber mat will do nothing as I suggested
the arcing is causing the static so it is severe
if the machine is under warranty , get it checked by a warranty technician or service agent
failing that the capacitor is fitted across the power and neutral points at the back of the power point
Posted on Feb 07, 2017
Testimonial: "Thank you, Where is the power point, an neutral points? It is not under warranty, and is 2nd hand. Kind of confused as to why this would need to be done. Thanks."
Sole elliptical e55 makes thumping noise
If you wish to get some details about elliptical and treadmill ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 28, 2016 | Sole Fitness Sole E55 Elliptical
I need schematics for Manufacturer's Product Number: 022670
Step 1:
you must find it. in www. fitnessrepairparts.com
however see the diagram attached FOR troubleshooting and fix it.
God bless you
Step 2:
Step 3:
Jan 08, 2013 | RTO Sole Fitness Package F85 Treadmill &...
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
Operating manual sole e35
go to www.iconservice.com for free download
or http://fitness.manualsonline.com
Good luck,sincerely. G-d bless you
ERNESTO CUADRA
MANAGUA,NICARAGUA
Dec 12, 2011 | RTO Sole Fitness Package F85 Treadmill &...
SOLE E95 "Ramp Error" Message
Thanks! It was the calibration!
But in order to get to calibration mode I had to press "Resistance Up" and "Start", not "Incline Up" and "Start"
Aug 07, 2011 | Exercise & Fitness
The display lights up on my treadmill but the belt doesn't move
Unplug your unit remove the motor shroud then plug unit in now on lower board their should be some LEDs Get on the the unit and with one of your feet push the belt now one of those LEDs should flicker this is tell you that the speed sensor is good. Now with you feet on the side foot rails hit start you should see another LED flicker this is your PWM this signal tells that the upper console and cable for the most part is functioning. Now if the belt at this point If you have a multi-meter put in on dcv 100v connect where the 2 leads coming from the motor and see if there is any dc voltage generated. If the motor is still not moving last I would check is the motor itself unplug the unit take the motor leads off connect your meter lay the meter down where is completely visible, get back on the the unit and with one of your feet push the belt now you are generating dcv for all intensive purposes the if is reading then the motor is good Replace Lower board if motor iis not reading replace motor
Apr 12, 2010 | RTO Sole Fitness Package F85 Treadmill &...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
