Question about Panasonic TH-42PZ77U TV
The color has changed from great to washed out with too much red and green.
    Problem Solver:
  • 14 Answers
Go to Tweaktv.com. There you can find the correct setting for your set.
Posted on Jun 23, 2009
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
My printer is printing in hues of green colors
HOW DOES THE TEST PAGE COME OUT?
If the test page also does not print properly, maybe you don't have run out of red and yellow color in the cartridge.
luciana44
Dec 26, 2009 | Canon MP610 Photo All-In-One Printer
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
53" sony projection -picture washed out w/ green horizontal lines
It sounds like your Green CRT ( picture tube ) is shorted. That's the one in the middle. Sony had issues with there tubes in those years. Sorry for the bad news. Even if you could locate the tube, it will be a matter of time before the Red or Blue does the same.
May 03, 2009 | Sony KP-53S65 53" Rear Projection...
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
Wiring problem
yes that is right, color to color turn of breaker before touching wires. green and bare copper go together.
Nov 01, 2008 | Jenn-Air JED8430 Electric Cooktop
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Loss of color - all green
yes! the problem is in the CRT board the RGB colors! you have lost of blue and red! thats why your unit is green! and only green is worked the blue and red is not work! maybe you have lost contact of them! resolder all CRT board to comeback the normal picture!
Sep 28, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Panasonic TH-42PZ77U TV Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
