Question about GE J Series 20.6 cu. ft. Top Freezer No-Frost Refrigerator TBX21JABWW
Breezaire wkd1060 wine cooler runs but blows warm air. One of two fans not running. Is this the condenser and where would I find a replacement.??,
peyton32034
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
SOURCE: Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Posted on Jun 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: Coil fan will not run.
Replace the master control circuit board on the rear of the fridge.
Posted on Jun 22, 2009
Macmarkus
  • 2605 Answers
SOURCE: GE Profile fridge: freezer is
Hello, welcome to FixYa.
I understand based on your post you have a GE profile PFS22MIS fridge not cooling in the fridge (upper cabinet) section, correct ?.
It is possible the problem is related to the condensor fan, but not likely. The difference with these fridges and many others (especially the older fridges) is the condensor fan does not run all the time. Instead the control board at the back (pcb) tells it when to run and at what rpm to run as well, it is a variable speed fan motor...and may in fact not run at all at periods.
The one thing I'd suggest you inspect is the back wall of the freezer. You mentioned the evaporator fan motor is operating, correct ? Is there any frost build up on the back wall of the freezer section, or if not visible have you removed the back wall of the freezer ?
I will need to watch for your reply before going forward. I hope you can appreciate there are so many variables since the fridge has many factors controlling air flow which in turn determine what the possible problem and solution will be.
Sounds to me it is a damper or blocked evaporator initially at least. Let me know what you find and we'll go from there.
Regards,
Macmarkus :)
Posted on Sep 20, 2011
freddylou703
  • 6 Answers
SOURCE: My GE fridge PSi23SGNA BS freezer defrosted.
Replaced motherboard part # wr55x10942 $75 on ebay.
Posted on Jul 27, 2012
How do you open cabinet to replace fans on a Breezaire WK2200 unit?
YOU WILL HAVE TO DRILL OF THE RIVETS ON THE SIDES OF THE UNIT USING A 1/8 DRILL BIT, ONCE YOU DRILLED THEM OF YOU WILL TAKE OF THE COVER ON THE UNIT AND YOU WILL SEE BLUE INSULATION ON IT, REMOVE THE TOP INSULATION COVER AND FANS WILL BE EXPOSED, THEY HAVE QICK DISCONNECT LEADS ON THE WIRES, DISCONNECT THE WIRES, UNSCREW THE FANS WITH A PHILLIPS SCREW DRIVER, INSTALL NEW FANS AND REMEMBER TO TIE STRAP THE WIRES FROM THE NEW FANS TOGETHER SO THEY DONT MOVE.
Jul 13, 2014 | Breezaire WKE 4000 Wine Cooler Unit - 1000...
Refrigerant lose
YOU WILL NEED TO REPLACE THE CONDENSER COIL(HOT SIDE OR BACK OF THE UNIT) AND RECHARGE THE UNIT SAME AS IF THE UNIT HAD A REFRIGERANT LEAK.
COIL IS ABOUT $95
Feb 27, 2014 | Breezaire WKE 4000 Wine Cooler Unit - 1000...
I have a WK Breezaire. The condensation line is clogged up. I need to get inside the unit to clean out the pan.
YOU CAN TRY USING A SHOP VAC TO **** OUT BLOCKING MATERIAL OR TO BLOW AIR THROUGH THE DRAIN HOSE TO PUSH THE BLOCKING CONTAMINANT.
BEST WAY IS TO DRILL OPEN THE UNIT USING 1/8 DRILL BIT TO REMOVE THE RIVETS AND TAKE THE COVER OFF, THEN REMOVE THE RIVETS THAT HOLD THE FAN DECK TON ON THE FRONT OF THE UNIT AND TWO ON THE BACK OF THE UNIT TO BE ABKE TO REMOVE THE INSULATION AND EXPOSE THE DRAIN HOSE HOLE, FLUSH WITH LOTS OF WATER AND A BRUSH AND ALLOW UIT TO DRY WELL BEFORE RECONECTING TO THE POWER.
Aug 24, 2011 | Breezaire WKL 4000 Wine Cooler
Evaporator ices; unit does cool
TWO POSIBILITIES
ONE IN MAJORITY OF CASES IT IS A SYMPTOM OF A FREON LEAK, ICE FORMS ON COIL, UNIT MAKES NOISES AND IT WILL GRADUALLY LOOSE COOLING RUN NON STOP AND THEN IT WILL PRODUCE HEAT
SECOND
A BAD FAN ON THE COLD SIDE OF UNIT THAT REDUCES AIR FLOW PASSING BY THE COIL AND ALLOWS IT TO FREEZE, IN THAT CASE IT WOULD NEED A FAN REPLACEMENT, YOU MAY CONTACT THE MANUFACTURER FOR A REPLACEMENT FAN
May 16, 2011 | Breezaire WKCE 2200 Wine Cooler
We have a danby dwc283bls wine cooler that no longer cools, and the compressor gets warm (above normal) does it need to be recharged
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Apr 15, 2010 | Danby DWC283BLS Wine Cooler
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Jan 28, 2010 | Marvel 61WC Wine Cooler
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
