Question about Indesit IWE81281 White 595 mm Washer Front Loading, 7kg, A Energy Rating
How do I unblock conditioner tray indesit iwe 81281
2 Suggested Answers
SOURCE: Fabric conditioner not going
Check the solenoid belongs to that tray.It may struck.
Posted on Jul 05, 2009
I can not take the detergent drawer out to clean it out of my new indesit washing machine IWME126
The following I pre-typed for another problem but contains the answer in the second option- I had great difficulty removing the tray when we borrowed our daughter's Indesit! It is necessary to actually watch what is happening from underneath the tray ;-0)
Follow the rest of the instructions on a regular basis and the softener will always be siphoned into your washer.
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube
but on others the cover is part of the tray's plastic top. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 22, 2011 | Indesit W 123 Front Load Washer
Despite cleaning and also running a cleaning fluid through a wash, my machine is not taking my fabric conditioner from the tray - can you advise?
Despite cleaning and also running a cleaning fluid through a wash, my machine is not taking my fabric conditioner from the tray This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 16, 2011 | Indesit Washing Machines
The fabric conditioner is still in the machine at the end of the cycle
This is a common problem with many machines.
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following (probably the second)-
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
John C
May 19, 2011 | Indesit W 123 Front Load Washer
The fabric conditioner is still in the drawer at the end of the cycle
(and again!)
Remove the complete drawer. To do this you will have to do one of the following- (probably the second!)
One of these should enable you remove it
John C
May 19, 2011 | Indesit Washing Machines
I want to remove the powder draw on the indesit wi101 without breaking it as i need to clean it
When cleaning pay p
articular attention to the latter sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-(the second one!)
(I am having to guess some of the following!)
John C
Apr 25, 2011 | Washing Machines
How to gt the soap dish out of an indesit
Here are my general guidance notes; I suspect yours will be the same as our daughter's ;-0)
Good luck,
John C
Mar 03, 2011 | Indesit W 83
Conditioner not filtering from drawer, model WG1285.
I suspect that the conditioner/softener tray is blocked UNDERNEATH its cover so it needs a thorough clean!
  • push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit!) or
It will normally have some sort of cover on it which you must remove to expose the little stuck up pipe/tube. This is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
I hope this is your problem and solution!
Good luck,
Feb 18, 2011 | Indesit Washing Machines
The fabric conditioner container in the washing machine is always full of water after a wash
What follows is my 'standard' reply document for this type of problem, slightly modified for your problem then copied and pasted!
Although you do not say which model it is, this is a common problem with many machines.
I suspect that it is 'gunge' in the conditioner/softener tray which is causing water to remain so it needs a thorough clean!
  • release the catches underneath (for most Indesit models) or
Good luck,
John C
Feb 13, 2011 | Indesit Washing Machines
When washing iwe get a horrible smell like bad
Is this a newly installed machine?
That smell would normally be associated with drains, indicating that the outlet from the machine to the drain is not correctly fitted with a trap.
Mar 25, 2010 | Indesit W 123 Front Load Washer
Jul 05, 2009 | Indesit WA 125 Front Load Washer
Indesit IWE81281 White 595 mm Washer Front Loading, 7kg, A Energy Rating Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
