Question about Brother MFC 9180 All-In-One Laser Printer
Leaves a line only when using feeding tray - Brother MFC 9180 All-In-One Laser Printer
    Habit-Forming:
  • 41 Answers
When you open the top feeder as you would when wanting to place an original on the glass to copy, you will notice on the left a very narrow glass. Look carefully and remove any dirt, white out etc.
Posted on Jun 11, 2014
Where is the manual feed
I think, there is None.
You have only tray 1 so manual feed must also be done using tray 1 by taking out all the other papers
If that is too inconvenient, get the optional tray 2. Fill that with paper and leave tray 1 for manual feed
Nov 02, 2013 | HP Officejet Pro 8600
Black vertical line down the middle of my copies? This only happens when using the feeder.
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,
The Manual feed tray Uses A feed roller and a Seperation Pad
If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller
Instructions:-
open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .
close down the Service Hatch and return to machine -
You may need to run several pages through tray one before all tread marks Dissapear
Sep 13, 2013 | HP Color LaserJet 5500 Printer
Printer feeds multiple sheets and james sometimes will not feed.
This is a very general question, for which I will give very general responses.
There are two (again general) reasons why these problems come up. The most common is that the feed rollers have become worn and/or impacted with paper dust, and will not pick up the paper correctly. If your printer has a "clean feed rollers" utility (some do) then use it. If not, and if you can reach the rollers, you can try using a slightly moistened piece of t-shirt material (DO NOT USE PAPER TOWEL or anything else that can leave lint) to lightly swab the rollers to remove the paper dust, etc. Be very careful. It's easy to break plastic parts.
Another reason may be the paper itself. If you live in a humid climate (I live in the tropics...this is an issue here) then the paper can absorb moisture as it sits, which will cause it to stick together in the feed tray. If this is an issue, keep your paper in plastic bags to keep the moisture out until you're actually ready to print, and don't leave paper in the feed tray for extended periods.
Another reason can be static cling. Always flex and fan the paper stack, then re-square it, as you place it into the tray. This separates the sheets and causes the "cut edges" (which can stick together from the packaging process) to let go of each other.
Hope that's helpful.
Dec 31, 2010 | Office Equipment & Supplies
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
, line on copy when top feed tray is used
clean the small glass left of the platen ... you probably have some white out on it
Oct 22, 2009 | Office Equipment & Supplies
The water solinoid is not sending water to my ice tray
Had the same problem. As long as the ice machine is still moving, meaning its working but just no water is getting to the ice tray.  order part #2205762 valve, solenoid and change it out.  It is not hard to do if you pay attention to how you take the old one out.
Feb 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Line down the right stide in the megenta area of the self test and blurrred print on the right side
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Oct 31, 2008 | HP PSC 2175 All-In-One InkJet Printer
Printer powers up, then down
Step1
Step
Step
Step
Dec 28, 2007 | Tally Line Matrix T6090 Printer
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
Brother MFC 9180 All-In-One Laser Printer Logo
27 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
