Question about Kitchen Ranges
I have a Honda Elite 1998 CH80. Throttle won't increase when handle is rotated. I replaced jets and checked vac housing, adjusted needle height. Engine turns fine. Runs great at one speed.
    Genius:
  • 1,114 Answers
With the engine off, Check the linkage cable from the handle to the carb, making sure , at full throttle at the handle the carb is at full throttle.
Posted on May 15, 2014
2 Suggested Answers
  • 1417 Answers
SOURCE: The front and rear legs
hello,
The way out of this is to carefully unscrew(open) the screws from the back of the range with the basic tools for it ,then take out the back cover then you will fine the screw at the angles use as key on the legs closer to the wire connected to the element ,then remove it carefully if needed.
please not you most be very carefully with other wire connection while carry out this assignment in order to avoid more damage on the range.
hope this help in solving the problem.
thank you.
Posted on Sep 03, 2010
Honda CH80 timing
Hi, Teddy for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2005 Honda Elite CH80 don want to start or run
Honda Elite 110 600 Mile Service Valve Adjustment Part 2
Honda CH80 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 03, 2013 | Honda Elite Motorcycles
2006 Honda Metropolitan dies when throttle opened
Hi, Anonymous and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
Idles but dies when throttle opened like many others
2003 Honda CHF50 Metropolitan Scooter woes VMaxForum net
Honda CHF50 2007 Metropolitan Owner Manual
Jun 25, 2013 | 2006 Honda Metropolitan
2000 HONDA XLR 125 R DIES WHEN THROTTLE IS APPLIED
Engine dies when increasing throttle or decreasing choke CBR Forum...
Bike idles perfect but dies when given the slightest amount of throttle 93...
Download Geek Search Honda Xlr 125 Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/227
Sep 22, 2012 | 2000 Honda XLR 125 R
2007 Honda Metropolitan stalls when throttle opened
Hi, Larry and the usual suspects are:
Idles good dies when given gas PROBLEM SOLVED Ruckus Central
Aug 21, 2012 | 2007 Honda Metropolitan
2009 Honda Metropolitan stalls when throttle opened
Hi, Joelacruz and the usual suspects are:
my scooter shuts off when turn the throttle
Jun 06, 2012 | 2009 Honda Metropolitan
2003 Honda Elite 80 will not start
Hi, Mskittleboy9 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
new to the honda elite 80 starting problems
Scooter Troubleshooting Scooter won start All about Scooters
Honda Elite SE50 Owner Manual
May 20, 2012 | 2006 Honda Elite 80
2000 Honda VTR 250 idles but dies on acceleration.
Hi, Gazza and the usual suspects are:
Idles fine but dies upon throttle
Idles but won accelerate
Honda VTR 250 Workshop Manual
Honda VTR250 Owner Manual
Apr 14, 2012 | 2000 Honda VTR 250
1995 Honda Elite 80 will not turn over
Hi, Salinasalex7 before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
24 So Your Honda Scooter Won Start
31GV4770 2006 Honda CH80 Elite Scooter Motorcycle Owners Manual Paperback... $20
Aug 07, 2011 | Honda Elite Motorcycles
2005 Honda Metropolitan stalls with throttle
Hi, Snoopyfan6 and the usual suspects are:
urbanscootin com Honda Metropolitan Scooter Forum View topic 2006 metro...
2005 Honda Metropolitan Scooter Rough Start and No Power
May 08, 2011 | 2005 Honda Metropolitan Base
Honda 2003 crf 230 bike idles fine with choke on,dies with choke off
You sound like you have a blocked idle jet in the carb. Honda trail bikes love new oil, clean air cleaners and clean fuel. After a while a build up of tannins and crusty residue will invade the carby bowl and usually migrate through the carb via the jets and the emulsion tube where the jet needle runs. The easiest way to fix your problem is to remove the carb and go through it. Clean all jets and check float height and generally get it back to scratch. You will have to re- adjust your idle and mixture settings after you have fited it back to the bike. If you are not Mechanicaly savi then I would suggest you take the bike in to your local honda dealer and get them to go through the carb for you.. It's not a big problem and is easlily fixed.
Hope this helps...
Cheers...
Apr 27, 2009 | 2003 Honda CRF 230 F
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
