Question about Pentair Minimax NT Heater
I have the MiniMax NT 300DV. When I push the pool button to turn on heat to pool it immediately snaps off. Readout is OFF. The diagnostic light on the ignition module flashes once when internal power switch is turned off to on. How do I fix an air flow fault? This situation has happened intermittently over the past 2 months, and has always previously corrected itself with time.
  • aeckels Jun 23, 2009
    Sorry, but I need further info- Clean what orifice, exactly? Where is it and how do I access it?
  • 258 Answers
Looks like you need to clean the orifice, normally dirt gets in there or spiderwebs that would explain to me why its been coming on and off , best way to clean is to use a pipe cleaner or remove them and clean ok, that should solve your problem, happy swimming
Posted on Jun 23, 2009
  • Brett McGuigan
    Brett McGuigan Jun 23, 2009
    the gas orifice is the jets under the flame sensor, check for for obstructions, usually webs. In fact check them all. If nothing, check flame sensor- clean anything off it, a little sand cloth will work, have you cleaned the filter, make sure theirs nothing stuck in or behind the vents, it can shut off if it cant let out the air flow, check the wiring, are they on tight and clean
Why doesn't my Pentair Minimax NT heater fire?
Does it try to fire? Do you hear the blower kick on? If it only says E-- you might have a bad control input board. For it to fire the thermostat light, and pressure switch light must be lit up. Also you must push spa or pool mode on right...
Apr 29, 2015 | Pentair Pool & Spa
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
I have a problem with my pool heater. When I turn it on, it turns itself off in only a few minutes. It turns off immediately when it starts heating up.
if there is any flex tube used for the gas line this will happen or you don't have enough gas pressure,or the pipe is to small.
Jul 31, 2011 | Pentair Minimax NT Heater
Minimax NT pool heater won't turn on but there is no error message on display. Just says "OFF"
You may have a bad board or bad keypad bezel. Try using the other thermostat button. Either Pool or Spa button should activate the unit.
Apr 03, 2011 | Pentair Minimax NT Heater
Pentair MiniMax NT pool heater not working
check breaker maybe popped check ignitor
Sep 29, 2017 | Pentair Minimax NT Heater
Err light on on pentair nt minimax. pushed power button, won't go off. any suggestions?
24 v at the transformer ? if yes unplug thesmostat probe if 888 change t probe if err change t board
Sep 06, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Jan 19, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
61 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
