Question about DreamGear TYPE 6 2.4 GHz Wireless Controller for PS3
The controller will not connect to the usb receiver connected to the PS3 game. Is there a reset button or something on the controller?
4 Suggested Answers
SOURCE: Problems connecting a ps3 controller
Here's how to connect it tou your ps3. Mine works perfectly guys.
1. Turn your ps3 off without the USB key given with the controller
2. Make sure your controller is off.
3. Turn on the ps3
4. Turn on the controller
5. Press on the sync. button of your controller.
6. Plug the USB key into one of your ps3's port
7. When the light above your controller starting to flash slower, just pess the home button and your controller will be sync.
You can't turn on the ps3 with this controller. So turn it on manually than press the home button of the controller to turn the controller on.
If my post doesn't solve your problem, I really don't know how to solve it. I managed to connect mine so I hope it'll be the same for you!
Sorry for my bad English folks! You know... french people =S
Posted on Feb 08, 2009
SOURCE: psyclone essential controller ps3 won't connect
the 1-4 lights flash on the dual shock 3 controller & it wont work is it broke or just charging? if it is charging how long should it take to charge?
Posted on May 24, 2009
  • 207 Answers
SOURCE: can't get it to connect to ps3
i don't know where you bought it but you should have gotten a usb receiver with your controller. you need that to be plugged into your ps3 and synch with your controller. here is the step by step from the beginning
http://www.dreamgear.net/lava-glow-wireless-controller-without-rumble.html
go down to the bottom of the page and look at the manual. and as you can see the controller comes with a matching usb receiver
Posted on Apr 29, 2010
My Intec controller will not connect to my ps3 don't no what to do.
Remove the USB receiver from the ps3 console usb port. Turn OFF the ps3 console and the controller. Turn on the ps3. trun the controller to on. press the sync button on the controller. Insert the usb receiver to the usb port. Press Home button. Now I had two controllers one I had to return because no matter what i did it did not link but the 2nd one did this way
Dec 29, 2009 | Intec PlayStation 3 Turbo Shock III...
Controlers wont sync with console.
Flip the controller over, and press the reset button. It's to the right of the middle-top screw . You'll need something like a paperclip, toothpick, or something similar to push the button. Once you've reset your controller, connect it to your PS3 with a handy USB cable, and press the PS button (just like you did when you first got the controller). Now, it is paired again, and you should be OK.
I've read that not allowing the controller to die will help prevent this, so try and keep your controller charged
If that doesn't work, another issue might be your cell phone and bluetooth headset (especially if you have the headset also connected to your PS3). Try turning off the headset, or if you use the headset on your PS3 as well as your phone, turn off your phone's bluetooth adapter.
Nov 25, 2009 | Sony PlayStation 3 40GB System
Does any one know how to add a second controller? I have tried everything!!
hook it up to a USB cord and connect it to your PS3, then hit the PS button to turn it on. It will register itself to the PS3.
Jul 20, 2009 | Sony Wireless Controller for PS3
Ps3 will not reconize intec in any way wireed or wireless. just invisible
CONNECTION A:
DO NOT INSERT BATTERIES INTO THE CONTROLLER; THE USB CABLE USED WILL SUPPLY THE POWER TO THE CONTROLLER.
STEPS # 1 – TURN THE POWER ON TO THE PS3 CONSOLE.
STEP # 2 – CONNECT THE USB CABLE TO YOUR PS3 CONSOLE AND CONTROLLER.
STEP # 3 – NEXT PRESSE THE SYNC BUTTON ON THE CONTROLLER, THE CONTROLLERS LED INDICATOR’S LOCATED ON THE FRONT OF THE CONTROLLER WILL START TO FLASH RAPIDLY.
STEP # 4 – CONNECT THE USB RECEIVER TO THE USB PORT ON THE PS3 CONSOLE.
STEP # 5 – WHEN THW CONTROLLERS LED INDICATOR’S LOACTED ON THE FRONT OF THE CONTROLLER START FLASHING SLOW PRESS THE HOME BUTTON.
WHEN THE CONTROLLER HAS ESTABLISHED A CONNECTION BETWEEN THE CONTROLLER AND THE USB RECEIVER ONE OF THE CONTROLLER’S LED INDICATOR’S WILL BECOME SOLID RED.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
Ps3 controller wont connect to ps3
-Press the tiny reset button on the back of the controller
-Plug in the USB Connection wire
-Restart Console
-When loaded, Press the PS Button
Hope it works mate :)
Mar 15, 2009 | Sony Wireless Controller for PS3
PS3 controller disconnects while playing games or watching DVD's. Have tried leaving it plugged into the usb port all the time - still disconnects. I then have to reboot the console to get the controller...
Check the controller settings under,
SETTINGS, Powe Save Settings, Controller Auto-Off
If that doesn't work try performing a hard reset on the controller like this:
Flip the controller over, and press the reset button. It's to the right of the middle-top screw ps3_controller_reset.jpg. You'll need something like a paperclip, toothpick, or something similar to push the button. Once you've reset your controller, connect it to your PS3 with a handy USB cable, and press the PS button (just like you did when you first got the controller). Now, it is paired again, and you should be OK.
Let me know what happens.
Feb 27, 2009 | Sony Playstation 3 (PS3) Console
Problem with ps3 controller
Try hard resetting it by doing this:
Best of luck!
Feb 25, 2009 | Sony Playstation 3 (PS3) Console
Ps3 controller will not steer Motorstorm Pacific Rift anymore
Give this hard reset a shot.
Let me know if it works.
Best of luck!
How to set up yobo controllers for ps3
I just bought a used one today and took me a little while to get it to work. Plug the USB receiver in and turn on the PS3. Press the Mode button and the lights will flash repeatedly at a fast rate (it's searching for the receiver). When it finds the USB receiver, the lights will still flash, but slower than before. When they're doing this, press the mode button again, and that should be all that you have to do. You can also plug the receiver in USB slot one, the charge cable in slot 2, and do the steps to set it up to make it work while charging. (I tried taking the receiver out while charging, and the lights started flashing again so I guess the USB receiver has to be in at all times)
Jan 11, 2009 | YOBO FC Game Console
Bluetooth ps3
MASTER RESET
At front of the receiver there is a button. Press it down for 2 seconds. Next on the controller, hold the left 2 shoulder buttons down WHILE re-inserting battery. Press the SQUARE button. Your controller should be working as normal.
Oct 02, 2008 | Video Game Consoles & Games
DreamGear TYPE 6 2.4 GHz Wireless Controller  for PS3 Logo
124 people viewed this question
Top DreamGear Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Mushtaq Mahomed
Mushtaq Mahomed
Bruce Meyer
Bruce Meyer
Level 1 Expert
Are you a DreamGear Video Game Console and Game Expert? Answer questions, earn points and help others
