Question about Bladez Motion X450 Elliptical
I have a Bladez fitness X450 elliptical; I saw that someone had the same problem I'm having, flashing console and beeping; do you know if your suggestion fixed her problem. Please help!
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: bladez elliptical
see the steps and fix it. God bless you
Adjust the magnet with bolt attached there are loose, tight very well and ready the resistance is the main parts that need repair,
However if the resistance is faulty, you must test again the magnet from the refrigerator by attracting or repeled, if do not pass this test replace it buying small cheaping from home depot or similar.
GoD BLess you
  • 1 Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • Sponsored Links
  • 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Read more: How to Fix an Elliptical Machine ' eHow.com http://www.ehow.com/how_4681374_fix-elliptical-machine.html#ixzz2DLrv9YSH
  • Sponsored Links
    Posted on Nov 26, 2012
    Vision fitness X1400 elliptical thinks it's a bike
    Check for a switch on the back of the display - you will need to remove the display to get at the switch.
    Aug 30, 2014 | Exercise & Fitness
    My Schwinn 428p Elliptical is stuck on level 1 Rest of computer seems up be working
    Either motor or brake....cable unlikely. Make sure the console buttons beep and check above.
    Jan 20, 2014 | Exercise & Fitness
    Sole E55 console display flashing "Need Lube"
    Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
    You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
    Thanks Tyler! Happy exercising!
    Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
    When plugging in my BLADEX x450, computer portion lights up, continually blinks and occassional beeps. Control buttons do not work. Unable to reset the computer
    1) adjust the REED switch, see the diagram , test for open or faulty, Clean it, and tight the connector very well.
    2) tight the ribbon cable inside from dispaly for keypads control,clean it
    3) replace the batteries by new one, REChargeable hybrids rayo-vac with the mark, polarity.
    God bless you
    Jan 07, 2013 | Bladez motion x450
    Too difficult to use even on easiest setting
    ask your persona trainer what he recommend you, in base to your need physical.
    God bles you
    Jul 16, 2012 | Bladez Fitness X350P Homecrosstrainer
    Looking for a bladez DKS200 mobility scooter battery case?
    http://www.bladezscooters.com/
    http://www.monsterscooterparts.com/
    Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
    May 03, 2012 | Health & Beauty
    Monitor diplays E1 and won't stop beeping
    Fitness Quest Eclipse 1175e Elliptical Trainers were recalled on December 11, 2007 for a fall hazard. During exercise, the foot pedal crank can break. After receiving 190 reports of the crank breaking, the company is offering a replacement product or credit toward other Fitness Quest products. If the pedal falls off, be sure to save it; you will need the right foot platform to claim the replacement or credit.
    Owners should stop using the elliptical trainer immediately. Owners can receive a replacement with another Fitness Quest product or credit.
    Eclipse Recall Instructions and Form (PDF)
    Questions? Contact Fitness Quest at: (800) 321-9236 between 8:30 a.m. and 8 p.m. ET, Monday through Friday. Or, e-mail productrecall@fitnessquest.com.
    The Fitness Quest Eclipse 1175e Elliptical Trainer was sold at major sporting goods chains, such as Sports Authority, Modell's, Dunhams, and JC Penney stores in the United States from September 2006 to October 2007. Sale prices were $290 and $450.
    E1 errors are usually lubrication/resistance issues. Has the unit been oiled/greased recently?
    Jan 10, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
    Bladez Motion X450 Elliptical Logo
    Top Bladez Exercise & Fitness Experts
    Electro Med Services...
    Tom Chichester
    qa1012
    Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
