Question about Lands Phones
Comdial Impression - assigning extension to company directory.
We have Comdial Impression phones and are having trouble getting assigned voice mail boxes to be available on our company directory.
Example: John Smith has a voice mail set up. A caller phones in and receives the message that they can press the "star key" for a company directory. The caller dials the last 3 letters of Smith, the system states, "There are no names that match those letters."
cnavarro
  • 2460 Answers
SOURCE: Assign Extension Name
THIS MAY NOT APPLY TO YOUR SYSTEM SINCE THE U.S. VERSION TA IS NOT THE SAME.
From the System Manager's phone, go into programming and select program 604.
Posted on Oct 28, 2008
cnavarro
  • 2460 Answers
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Posted on Jan 21, 2009
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Posted on Mar 24, 2009
SOURCE: can't put ringtone on a specific callers number
lol i work at AT&T and after about 10 minutes of messing with it i finally figured it out...first you have to go to menu, settings, phone model and switch to advanced mode, then you have to make sure the contact u want to set up as a ringtone is saved to your phone and not the SIM card. go to that number options, edit, go down to default and push right on it and select the ringtone.
Posted on May 08, 2009
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7730- assigning speed dialing/one
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Carl
Posted on Jun 04, 2009
How do I find out what my mbox number is, it's not my extension.
Each mailbox has the ability to be assigned to a different extension number than the MB #. This makes it very difficult to manage a system when this happens. It will take someone with voice mail programming knowledge to get into the voice mail system to check each mailbox's programming to find it.
Aug 28, 2013 | NorStar M7208 Corded Phone
How do I activate a line on a Nortel system to set up a mbox without a telephone extension?
Hi!
All phones that are plugged into the system are automatically assigned an extension. This is a good thing, and it keeps life simple. When you have a specific line assigned to a phone, all it means is that you have the phone programmed to appear and ring on that particular phone set.
In short, find out your extensions number by pressing feature * 0 intercom. That will be the extension that you put in to add the mailbox to that phone.
Now, I am assuming that you are using a voice mail system. If you are not, then you can have your phone service provider set you up with an external voice mail on a particular line.
Let me know if you have more questions.
Jan 06, 2012 | NorStar M7310 Corded Phone
We need to set up a voice mail for an extension that has not been used in years. When I press intercom 777 and enter extension it tells me to enter password which no one in the office knows anymore. When...
The default password on partner voicemails is 1234. The reason for the call returning to the extension that transferred the call to the new extension is probably because the cover vms isn't set up for the new extension.
To check the vms cover for that extension, at either extension 10 or 11 press feature 00 and press the left hand intercom button twice. The display will say system programming.
Enter #310, the display will sayAutomatic VMS Cover Extension:
enter in the extension number of the new extension.
The screen will say either "1 assigned" or "2 not assigned"
enter in 1 (assigned)
press feature 00 when finished.
Sep 30, 2010 | Avaya Corded Phone avaparp18d
How do i set up speed dial on my KX-TG9391C
The speed dials are set in the contacts or the names directory. Open the directory and scroll down so that you see the options available to modify the names list. In this sub list you will find the speed dial. select this menu and open to see the locations 2-9. Since no 1 is assigned for voice mailbox you can assign the rest from 2 to 9 by select the destination and assigning with the selected name. Even for the no 1 voice mail box you can assign a name but must select it from the settings menu in the messages window, Now try to press and hold the set numbers to confirm that you speed dial works fine, Hope you try this out. Good day
Jul 29, 2010 | Panasonic Lands Phones
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
press feature "00" to logout
Oct 06, 2009 | Lands Phones
Ring back on 18D
If you have enough voicemail boxes go to ext 10 or 11
Press feature 00
Left intercom twice
#310
enter extension number
press 1 to assign
Feature 00
Jan 16, 2009 | Avaya Corded Phone avaparp18d
New to system, need to set up 3 voicmail exts.
Begin with what do you have for a voice mail? If it's a Panasonic brand, you log in as administrator (mailbox 999) and create the mailboxes. It is usually done at installation, unless your installer closed them down to prevent fraud. It's option 6 1 1 and you enter the mailbox you want to create. If it exists, it will tell you so, if not, it will create one. Then follow the prompts to assign an extension to the mailbox, and give it a name.
The extension user then dials the voice mail access code and creates greetings and a name and sets the password.
Carl
Oct 15, 2008 | Panasonic KX-T7731 Corded Phone
Voice Mail
if you can not transfer a call to voicemail, there isnt a mailbox made. If you transfer a call and it doesnt go to voicemail, then there isnt a mailbox OR it isnt assigned to the voicemail group.
To assign a phone to go to voicemail (if there is a mailbox made)
at extension 10 or 11
press feature 00
LEFT intercom
Left intercom
#310 (auto VMS cover)
group 7
enter extension number.
If it says 2 not assigned, press "1" so it says assigned.
Press feature 00 when done.
If it still does not work, you need to build a mailbox. Will need to know EXACTLY which voicemail it is in that case.
Jan 15, 2008 | Lucent PARTNER18 Corded Phone
Lands Phones Logo
83 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
