Question about Scotsman Ice Machine - 290lb Self-Contained Air-Cooled Cuber - SCE275A-1H
What can I do to fix cem256 ice machine that the refigeration light blinks twice ?
I have cleaned the ice been eyes, unplugged it let it set and tried it again, checked all the molex connections ( they where all nice and clean)and it still make one batch or what I thank one batch should be and it throws the code of the refrigeration red light blinks twice witch is (harvest cycle time limit reached ice not sensed ). What do I need to check or replaces SN 06021320015292 Thanks for your time and help I hope.
  • 23 Answers
Http://hvac-talk.com/vbb/showthread.php?679751-Scotsman-CME256-Water-Diagnostic-Light-Problem
Posted on May 15, 2014
  • 4 Answers
SOURCE: The scotsmand machine make ice, but quantity of
Scotsman unit is the CME1856 water cooled
Average batch weight= 20lbs
cycle time 15-17 min
Production 1825-1695/24hrs.
Need more informaton
sensors not the issue unless there on all the time or not blinking as ice passes the infra red signal.
Remember this was a very hot summer and ice demand was high is it possible you have experianced increase volume?
Check controller for error codes and call 1-800-533-6006
Posted on Nov 29, 2010
kel1guy2002
  • 3740 Answers
SOURCE: it says harvest time maxed
Hi and welcome to FixYa, I am Kelly.
Download this manual and read page 19 carefully.
http://www.scotsman-ice.com/docs/uploaded/sct/manual/275m.pdf
I think you have a thermistor problem. But... there are several things that will cause the 8 minute max harvest time error. See the diagnostic lights chart on page 19.
Diagnostic Lights:
There are two RED diagnostic lights, one to indicate a water problem, and the other to indicate a refrigeration problem.
Both On all the time / Check for thermistor set unplugged or failed
Additionally see the troubleshooting chart on page 27 "Unit OFF for a harvest problem"
Also make sure to read page 15. The thermistor inputs are on connector #5 left side of the controller
Resets:
Note: The machine may be reset and restarted by
pushing and releasing the Off push button switch,
and then pushing and releasing the freeze push
button switch.
Lastly after a RESET read the initial start up procedures on page 12 right side with regards to the harvest cycle steps 1 - 8.
Thanks for choosing FixYa,
Kelly
Posted on Mar 10, 2011
bobicehouse
  • 1524 Answers
SOURCE: Hello, I am a Certified
Download this manual. On pages 20&21 are cleaning instructions. Also install a water filter.
Posted on Jul 12, 2011
qasolution
  • 107 Answers
SOURCE: machine goes to off....red light flashes (refrigeration light) if I press off and then freeze..machine will come back on and make ice but will not dump
check dump valve
Posted on Apr 18, 2012
qasolution
  • 107 Answers
SOURCE: cleaned ice machine because desale
make sure you press the clean button let run 10 min or so then press it again.if you dont press it the second time descale will not reset.
Stops cycling intermittantly
Any advisory lights on, e.g. bin full? Clean all sensors and make sure dump valve isn't letting water gradually drain out
Apr 04, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman C0322SA error b after a cleaning which is bin full and there is nothing in it and can reset and tried unplugging for a half hour nothing
This machine has a set of bin eyes that get dirty and it brakes the beam causing the machine to think the bin is full. pull front cover off, pull ice deflector off, where the sump tray is which is where the water returns back there is a plastic grate in there pull it out now reach is where the ice falls into the bin there is two bin eyes one on right side one on left side they will have a gray wire running from them both to the control board you can reach in and pull them straight out to the side the mounts are either gray or black there will be a little red light on them clean these and re install them also there will be a tray that rest above them make sure you push it back up before putting them back in. this will clear the bin full code and start machine up.
Sep 02, 2013 | Kitchen Appliances - Others
How do I fix the max harvest time shutdown
The ice sensors are not sensing the ice fall.Wave your hand in front of them the bin full light should blink.If it doesnt clean eyes and conectors.If it still doesnt blink change them they are bad.
May 21, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Freezer freezes than thaws completey all items thaw out???
call the repair man now they have a twenty four hour service,they can loan you a refigerator,to use while youres is getting fixed it could be the compressior is every thing clean from underneath is the defrost pan full of water is the defrost drain tube blocked is the vent clean from lent. this needs to be checked twice a month,even if you dont think so. try unpluging it then pluging it back in is it the gp plug,did the breaker go off is the light on?let me know
Aug 29, 2010 | GE Refrigerators
Cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Apr 15, 2010 | Scotsman Cooled Modular Contour Cuber Air...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Scotsman Ice Machine - 290lb Self-Contained Air-Cooled Cuber - SCE275A-1H Logo
460 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
john h
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
