Question about Toshiba 52HM95 52" HDTV Projection Television
I have a toshiba 52hm95 DLP tv and i am trying to get the souund to run through my tuner. i attached the digital audio out on the tv to the "digital audio in" in my tuner and i am not getting any sound. Any ideas?
    Problem Solver:
  • 14 Answers
More than likely you need to set the tuner up for this. On your DUI "Digital User Interface" you will need to go into the digital in assignment and select the digital input, you should have the option's of, coax, optical or analog. Select COAX and you should get sound.
Posted on Jun 23, 2009
Where are toshiba dlp 62hm95 fuses
I looked at the power board online and I do not see any glass fuses.
I only saw the pico fuses which you unsolder and resolder.
Here's an image of the power board: http://tvpartsandmore.com/wp-content/uploads/imported/46HM95-TOSHIBA-23764257-POWER-SUPPLY-UNIT-46HM95-52HM95-62HM15A-62HM95-62HMX95-191208846050.jpg
What is the problem with this TV?
www.aaatvservice.com
Aug 15, 2014 | Toshiba 62HM95 62" DLP HDTV
How do i change from 480i to 1080 on my Toshiba 52HM95 DLP im trying to hook up my playstation 3 with an HDMI cable but it wont switch over to 1080i
Most TVs choose the resolution based on the signal coming in. Be careful if you try and use 1080P. Not all TVs support it. 1080P is only on HDMI. set the playstation to 1080i before connection.
Some TVs and Playstation HDMI do not mix well due to software in the HDMI ports. Try RGB cables.
Apr 02, 2010 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52hm95 will not come on , red light blinks
It is the Light assembly engine. Happened to me It is $700 to fix and the wanartee on the new part is 3 mos
Aug 13, 2009 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52" HM95 DLP green and red LED Blink>
If Fan behind Lamp is not running lamp will not come on,also CK blaster board.
Aug 09, 2009 | Toshiba 52HM95 52" HDTV Projection...
How to install a converter box on the tv
First Converter boxes are a poor economic investment.
Second you have an HDTV. It does not need a Converter box.
Just connect an amplified antenna.
Specs:
Built-in ATSC QAM Tuners - QAM and ATSC tuners included to enable the set to receive Digital cable-in-the-clear signals, as well as digital terrestrial broadcasts. HDTV reception is possible by adding an Optional HDTV antenna
Mar 24, 2009 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52hm95 DLP HDTV - no sound
What cables are you using? Some TV's and DVD players have options to set your audio source. My DVP5982 I have to set it to HDMI digital audio, check to see if you have that on your TV.
Jul 04, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52hm95
I'm not sure if you are aware of this, but the 52HM95 tv has 3 fans inside. I believe one of them runs all the time.
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Permanent white spot
can see it in certain lighting and even when the TV is off! It will appear lighter than the surrounding areas at times and can be annoying. I called Toshiba and had a service man come out and even though he acknowledged that this is common, Toshiba will not replace the screen.
Dec 31, 2007 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52HM95 52" HDTV Projection Television Logo
117 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
