Question about Saws
Bogs down while cutting does carb need adj. - Saws
    Master:
  • 359 Answers
Every saw is going to bog down some when cutting. What condition is the blade? I would need more information on what kind of saw it is in order to try and help. Is this gas powered? Wet saw? Wood, concert or steel?
Posted on May 15, 2014
I'm having a few problems with my Gilera the bike starts up fine and doesn't cut out or anything just stays at 1000rpm but if you go to say 6000rpm the bike bogs out and then goes back to 1000rpm
Probably a carb issue. It sounds as though the idle jet is clear but the main jet is blocked. So your bike starts and idles, but as soon as you ask for more fuel, not enough gets through the main jet and the bike bogs down. Buy a manual and a can of carb cleaner, take the carb off, remove the bowl, remove the jets and leave them soaking in carb cleaner overnight. You might need to use some fine wire to poke through the jets if they are very blocked..
Jul 17, 2015 | Gilera Motorcycles
Does cut off saw need carb adj. it bogs down while cutting
It sounds like you are cutting something heavier than your saw can handle. I would check the manual and the limitations of your saw. If it is getting bogged down when sawing very small, thin things then the chain might need to be replaced. Don't keep using it until you have replaced the chain if that is the case.
Elisa Jed ' http://www.ascotconcretecutting.com.au/services.html
May 15, 2014 | Saws
Bogs down after warming up
check exhaust port first. then carb adjustments, then either crankshaft seals or carb needs replaced... You cannot adjust carb, it has to go to a certified center for this procedure... Thank the EPA for this B.S. and no you cannot by the adjustment tools on Ebay.
Nov 26, 2013 | Echo Garden
I hve a yamaha 1995 jetski an bogs down sumtimes on acceleratiotion.
Sounds like you might have a little water in your fuel system, check the fuel filter for water then clean carbs, dont forget to check the gas tank for anything sitting in the bottom.
May 01, 2012 | Yamaha 12V Air Pump
Suzuki lt 50 quad starts and wil tick over but when u try 2 rev it she bogs down and cuts out like a blo9cked carb but i'v had the carb off and its all clean and fine
I got a Suzuki lt 50 it starts fine drives fine at low speed then when I go over half throttle it bogs down I've cleaned the spart plug cleaned the carb and cleaned the jets but its still doin it any ideas please ??
Sep 16, 2011 | Suzuki GSX 750 ES Motorcycles
Brand new today Poulan P1500..Started, warmed up. Went to accelerate and it just bogged down and died with no cutting load on it. From what I am reading on forums Poulan is going to give me problems. I...
you have 2 options, return it or use a dremel tool and cut a slot in top of low speed jet screw and turn counterclockwise bout 1/4 turn, keep in mind if you do this it can't be returned, I have seen a lot of good poulans and a lot of bad poulans, flip a coin !
May 04, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
What are the carb. adjs. on a Mc culloch chain saw model cs 38em
If it bogs down like it's getting too much fuel, turn the low side screw out about 1/8 of a turn at a time until it will rev without bogging. If it chokes down like it's not getting any fuel, you probably need to open up the high screw a little.
BTW, you can determine which screw is which by looking at the carb at the base of the screw...it will have a L for Low or H for High stamped near it.
Jul 18, 2010 | McCulloch Garden
Have trouble starting homelite textron chian saw carb setting
First is the gas mix right? 2 ids the air filter clean? 3. have you replaced the tank fuel filter to make sure it's getting gas? 4. is the plastic line cracked? 5. adjust both carb screws all the way down gently then reverse the screws counter clockwise 2 and 1/2 turns, this should allow it to start and run, once it has started let it warm up and adjust the idle for it to run smooth without dying. Once its running rev it up to make sure it does not have any dead spots in it then try a test cut, if it bogs down adjust the gas screw to in rich it just a little and try cutting again if it does not bog down you should be set. there are other things that can cause it to run poorly like a bad carb gasket or loose screws on the carburetor. If you need more help post here and I will give you some other things to look at.
Nov 07, 2009 | Homelite Garden
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
Low power from low to middle rpm
Two strokes exhuast is very important for low end volumetric efficiancy. Check for cracks leaks and even crushed expansion chamber will effect low end performance.
Feb 09, 2009 | 2003 Yamaha YZ 125
Saws Logo
66 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
