Question about Magic Chef 1.6 Cu Ft Countertop Microwave Stainless Steel Mcd1611st
Why does my microwave arch at the wave guard
I start my Magic chef microwave and it suddenly starts sparking at the wave guard.
  • Sherry Scott May 19, 2014
    Thank you for your solution. After I posted my problem, I found that the mica wave guide plate had a split in it. I had a new one cut for me. Thanks again acm service!!
    Sergeant:
  • 224 Answers
Typically most arcing in a microwave is caused by food splatter. A microwave cannot tell the difference between what is on a plate or on the wall or ceiling. Every food particle in a microwave will continue to cook until it turns to carbon and will attract the microwave energy and focus it to that spot and the unit will arc. Thorough cleaning of the entire microwave cooking cavity and removal of any burn or soot mark will commonly stop the arcing. If your microwave has a painted cavity, you can even use some very fine sand paper to remove any burn mark. Always cover what you are warming and really keep the inside of the microwave clean. If your wave guide cover is made out of the Mica board, and If it has gotten wet from cleaning or from splatter, it must be replaced. You can either order a new one or order a sheet of the mica board and cut out a new one yourself. If the microwave is arcing in the waveguide, generally the unit will need to be replaced. One quick test to see if the unit will work is to remove the bad cover and place a small container of water in the unit, run the machine of a minute or so and see if it still arcs. If it does, the arcing is in the waveguide area, if not it may have just been a problem with the cover. You can run the unit without the waveguide cover in place, it is only there to prevent splatter from getting into the waveguide, so removing it to test the unit is ok. If the area inside the wave guide shows signs of soot and arcing. You can try to wipe that out with some alcohol or lacquer thinner and then try it again. Good Luck.
Posted on May 19, 2014
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The light is off on my Magic Chef MCD11E3W
Since the owner's manual doesn't cover it, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Posted on Nov 29, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Magic Chef Microwave Model MCO160S .
You can download that manual here.
Posted on Nov 27, 2008
SOURCE: magic chef over-the-range microwave shut off
I have a Magic Chef Microwave Model MC0153UB that is shutting itself off while cooking. I noticed before this, the light under the microwave blew during a storm. Do you have any suggestions?
Posted on Jul 22, 2010
heatman101
  • 43501 Answers
SOURCE: Magic Chef Microwave runs but no heat produced,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uitot
Posted on Sep 30, 2010
I have the Magic Chef MCD1311ST and when I hit the start button it doesn't start, but clicks and the timer counts down.
Her are the three most likely causes for your symptoms, but not in any particular order.
1) You may have blown a fuse.
If you will enter the make and model into the website of "SearsPartsDirect", you might get a schematic that will tell you whether your model has a fuse or not.
2) You may have a failed capacitor ( this is the "starter" for the magnetron)
3) You may have a failed "magnetron"( this is the heavy piece that makes the radio waves that cook your food.).
God bless your efforts.
Nov 09, 2017 | Magic Chef Microwave Ovens
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
PAPER DIRECTIONS
That FCC number means it was made by Daewoo, but it may have a Magic Chef or other brand name.
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
For Magic Chef in Canada call 866.587.2002
Jun 05, 2013 | Magic Chef Microwave Ovens
My magic chef microwave starts but immediately stops light work tho
No solution but keep it unplugged until you find one. Some units can cause a fire.
Feb 14, 2013 | Magic Chef CMV1000B Microwave Oven
The phone numbers I received from you are wrong numbers. They are not Daewoo. Can someone out there refer me to the right company to find a plate for my Daewoo microwave, Model KOR-1B4H.
There's overlap between Daewoo, E-wave, and Magic Chef .
Contact Magic Chef / Ewave customer service here.
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find parts or find your nearest authorized service center.
Oct 08, 2011 | Daewoo KOR-1B4H Microwave Oven
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Micro wave broke
open the door and look on the middle top right inside the microwave is it burned or blackend?You have a faulty magnatron.if it is.
May 19, 2009 | Magic Chef MCD1311ST Microwave Oven
Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Nov 24, 2008 | Maytag MMC5000 Microwave Oven
Magic Chef 1.6 Cu Ft Countertop Microwave Stainless Steel Mcd1611st Logo
143 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
