Question about Dometic Rooftop RV Air Conditioner
I HAVE A DUO-THERM AC MOD 59016.521 WHEN I TURN
I HAVE A DUO-THERM AC MOD 59016.521 WHEN I TURN THE UNIT ON I HERE ONE OF THE RELAYS CLICKING ON THE PC BOARD BUT NO OPERATION .WHEN I JUMP ACROSS THE RELAY BOTH FAN AND COMPRESSOR TRY TO RUN AND THE UNIT TRIPS THE COACHES 25 AMP CIRCUIT BREAKER. THE PC BOARD IS FOUND INSIDE THE UNIT NOT MOUNTED ON THE SIDE ONTOP......THANK FOR THE ASSIT.FRANK
bobotfel
  • 236 Answers
SOURCE: Duo Therm Air Conditioner Mod. 59136.331/ Control box E 6360360
Something wrong with your thermostat, but if you are using a electronic thermostat and have the indication of supply like light in your control then you can replace the miniature relay that triggers the cool mode of the unit. But no indication of supply try to check the fuse, then if not works you to replace new thermostat.
Posted on Jan 03, 2008
22yooper
  • 828 Answers
SOURCE: duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Posted on May 31, 2008
  • 659 Answers
SOURCE: Duo Therm compressor tries to start and kicks out
I don't think these little units have a start capacitor but what I would do is check that the on/off switch wires to make sure they aren't loose. Also check the wires to the compressor for loose wires as well. It is possible that these are the first signs that the compressor is about to fail. They also can act up some when they haven't been used for awhile and then you try and start them up. Try running the unit for a few hours without asking it to cycle. It might just be a sticky valve.
Posted on Apr 13, 2009
  • 340 Answers
SOURCE: My duo therm brisk air roof mount ac unit is
yep have the leak fixed and properly charged.
Posted on Jun 19, 2009
SOURCE: I have an 89 executive motorhome with a duo-therm
Hi! I had an 89 executive and have some spare
parts
Posted on Jan 05, 2010
Duo-therm will not come on makes clicking sound
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other help check out AC Repair Boca Raton we got you covered.
Jun 24, 2016 | Heating & Cooling
Dometic Duo Therm RV AC makes clicking noise when turned off
The braker is getting weak and needs to be replaced the act should be cleaned as the coils get dirty and make the units work harder
Jul 19, 2014 | Dometic Heating & Cooling
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Front AC unit will not turn on
The clicking tells me the AC(hydro) power has been turned off to it. Check all breakers, and make sure if you have another switch on wall, to change from front, to back, or to both, that it is in proper position.
Apr 17, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
A/c compressor runs, no fan
did you ohm the relays to verify a correct path? It sounds like the relay contacts are not "making" and providing a pth for flow.
Jul 12, 2009 | Heating & Cooling
I have a Dometic Duo-therm 1500 AC Model 59516.633C1 on my 5th wh
The clicking sound is usually the relays in the control unit making or releasing. When they click does anything turn on? Check the control unit that is located inside the lower unit of the air conditioner. Remove the cover and listen for the clicking sound. If it sounds as if the relays are clicking, try removing power from the thermostat and see if that stops it. There are three relays on the board, one is the compressor, one is the fan relay and the other is for heat. See if you can pinpoint which one is clicking and go from there. It is either that you have a bad thermostat or a bad relay board.
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
347 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
