Question about Marantz Audio Players & Recorders
Pm4001 I've been getting very muffled sound from left channel - changed interconnects, speakers, cables etc with no solution. Anyone any pointers?
    Top Expert:
  • Marantz Master
  • 6,702 Answers
If you switch the speakers, the sound goes to the right? if yes, your amplifier will be damaged. if not, you speaker or speaker cable is damaged. If you don't have the skills to repair an amplifier, don't even open the thing. Just visit a repair centre, to limit the damage (and costs for repair)
Manrantz often uses components with different (own) codes, so it could be difficult to replace any component you find defective. Without a service manual I even would not start a repair.
Posted on May 22, 2014
marsrover
  • 682 Answers
SOURCE: scratching sound in speaker conected to left channel
invert the speaker cables if the problem went to right speaker you will find a problem in your left speaker(cable or speaker)-if not you will have a problem in your amp itself.
Posted on Jul 14, 2008
Grubhead
  • 5056 Answers
SOURCE: Muffled/bad sound on 1 channel of Marantz PM4400 amplifier
Go directly to the main amp, follow the leads from the speaker terminals. And you should find something on an heatsink. If there are two transistors see if they are running hotter than the other channel. If you see any damage to them (compare with good channel) replace both!
If all you see is a black box with pins coming out of it you need to replace that. They sometimes have the letters STK on them.
Replace both types with the letters and numbers of the same type. IE 2SC 1220 or STK 589.
Posted on Feb 16, 2009
  • 9 Answers
SOURCE: Channels out of balance - remote will only change left channel.
switch input cables and try this will confirm if the amp has a problem or the input signal
Posted on Jun 25, 2010
caroldon
  • 17129 Answers
SOURCE: qsc 2450 amplifier not putting out equal sound to
First of all , the fault of a unequal volume levels is a fault to be looked in with some expertise. This is because of the fact that there is no failure but a difference in gain in some stages. If you have crossed over the speakers and confirmed that the fault is definitly in the amplifier. Now you will need to check first with a multimeter for diffferent bias in the preamp and power amp stages. If you have evidencce of a difference cross check to confirm. Next apply an audio signal from an injector and test from the preamp to the power amp. The section where the gain was noticed must be looked into and the gain corrected by checking variation of resistor/ capacitor values. You will need to replace fromt he working side- crossing the good part- to confirm the part before you buy and replace. Try this out but do it with caution when the circuit is powered , attempt only if confident and familiar with circuits. Hope I could help. Good day
Posted on Jul 24, 2010
petraman7
  • 1175 Answers
SOURCE: Poor sound from 1 channel
Hi...
My 1st thought would be a broken contact or 2 inside on the main volume control... Is the balance set to middle?
Is it the same with headphones?
Posted on Sep 27, 2010
Testimonial: "Thanks for that. I took the back off and blew it all out. Checked all the plugs then re assembled. Bingo !! all is good. Thank you"
Sound comes through only one speaker at a time.
Is the sound on both channels on a pair of headphones? If it is suspect a faulty headphone socket, especially if the speakers are cut out when the headphone jack is inserted - normally.
Jun 15, 2013 | Technics Audio Players & Recorders
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
Muffled Voices on Dolby DVD Playback
Most voices come out of the centre channel. Put your ear to that to see if it is working. If it is not then you might have somehow managed to switch it off. Check the cable connections to the speaker also.
Mar 12, 2017 | Sony Audio Players & Recorders
ONLY GETTING MUFFLED SOUND FROM ONE OF MY MACKIE SRM V2 SPEAKERS,HAVE CHANGED DIAPHRAM BUT PROBLEM STILL THERE
If you've changed the tweeter and the sound is still muffled the fault is with the HF amp, or the cross-over. You will have to send the amp assembly for repair as it is all surface mount components in there -nothing you will be able to fix yourself. Sorry for the bad news!
May 04, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
No power to the speakers no sound
only the left speaker out wont work on either a or b channel anyone know email me mikeyandjessie12@aol.com could it be the speaker wire its 10 gauge speaker wire so idk either channel ive checked its only the left out so i can only listen to the right out on each channel and i cant listen to both channels but does anyone know if you might be able to get a 4 in av cable to a 2 av cable and run 200ws out of this or no
Nov 14, 2010 | Technics SA-EX140 Receiver
I have a SAmsung HTZ310R home cimema system and recently been experiencing audio drop out. I stream movies from my PS3, and play BD's, watch DVD's. Havent had any issues until recently, when sound started...
Sounds like a couple of coincidental but unrelated symptoms.
Optical cables need precise seating and no tight bends.
Muffled, channel-specific sound is usually on the analog end. Speaker connections maybe.
Mar 17, 2010 | Audio Players & Recorders
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Problem with sound
Its easy. Jus from task bar click on that Speaker Icon of sound. In that you can select the left channel, right channel or both! Keep the pointer in middle and you will get sound in both the channels! Enjoy
Jan 16, 2008 | Audio Players & Recorders
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Mar 15, 2007 | Sony STR-DE545 Receiver
75 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
