Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
How do you replace the pull chord on a poulan pro 17'' cut 25cc weedeater
  • 246 Answers
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 279 Answers
SOURCE: Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Posted on Jul 14, 2009
woobie dog
  • 1273 Answers
SOURCE: how to restring
Pull the spool straight off of the machine. There are arrows on the bottom of the spool indicating the winding direction. Also, there are holes in the spool. Place the line in the hole just enough to hold it while you are winding the line. Not too far, say 1/8".
Wind the outer spool first, and put the end in the notch when the spool is full. Leave about a 6" tail and cut the line. Now wind the inner spool, and place the line in the notch that is 180 degrees from the first line's notch. Leave about a 6" tail, and cut this line off. Now, turn the spool toward the machine. While holding the spool, thread both tails of line through the grommets on the machine head, and work the spool onto the head. The tails should feed out the grommets as you do this. Seat the spool, you'll feel it click into place. Tug on the ends of the line to pull the line out of the notches. You're done!
Best regards, --W/D-- please feel free to rate this carefully hand-crafted solution! --thanx!--
Posted on Aug 10, 2009
#1 Taper
  • 1040 Answers
SOURCE: Poulan Pro Pp125 25cc Gas Straight Shaft
Here is my Tip(s) on this problem:http://www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Jim
Posted on Aug 14, 2011
  • 6468 Answers
SOURCE: poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
remove the muffler and try it if ok open the muffler and clean out the carbon from the screen
Posted on Apr 08, 2012
Testimonial: "yes that worked, but i did not have to remove the muffler.. i just had to take take a small screw driver and and slide the the screen out and clean it and slide it back in. my weed eater is running like new again.. thanks"
How do I fix my Poulan Pro bvm200fe?
If you do indeed have (good)fuel and spark to cylinder, I suggest you remove muffler and clean the internal screen/mesh and carefully scrape off carbon around exhaust port. Do not let debris fall inside engine when cleaning.
Repairing my STIHL FS 38 Clogged Muffler Fix
How To Troubleshoot Your Weedeater to crank every time
Feb 20, 2016 | Poulan Pro 25cc 2-Cycle Gas Blower...
What is gas mixture for weedeater poulan pro 25cc 17" cut
40:1 ratio is the manufature spec for 2 stroke units. unless it is a four stroke then there is no mixture just a good quality gas.
Jun 03, 2014 | Poulan WeedEater Hedge Trimmer 25cc Engine
I need a manual for a 25cc 2 cycle featherlite weedeater
try going on the internet to
poulan.com/manual, can d/l a manual from there
May 28, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
I have a Poulan WeedEater. It had trouble
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
How to restring my weedeater. it's a poulan pro 25cc.
Aug 10, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Jul 11, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
23 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
