Question about Canon PIXMA iX4000 InkJet Photo Printer
I would like to set up a paper size of 840mm long and 297mm wide on my Canon Pixma 4000 but the printer will not allow this size
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
Then there is nothing you cab do as printer is not made to handle this size
Posted on May 19, 2014
SOURCE: plz help.. for No legal paper size in canon lbp 1210 how to set t
i can do this job very perfectly
if u want 2 know 2 how u set legal in 1210 please call me 09872002075
Posted on Jan 18, 2009
Ajkill
  • 2035 Answers
SOURCE: Canon Pixma iP1500 printer indicates paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 29, 2009
SOURCE: Canon LBP 1210 paper size
want to canon laser shot 1210 drivers in ubuntu
Posted on Aug 01, 2009
  • 8 Answers
SOURCE: Pixma mx318 paper jam
The first thing I would do is check if there is any small fragments of paper in the printer. If you still cannot see anything, try getting some compressed air and blown the printer out. If that still dose not fix it, you might have a faulty paper sensor. If the printer is in warrenty, I would try and do a warrenty claim.
Posted on Aug 29, 2009
Testimonial: "thanks. very helpful."
SOURCE: My Canon PIXMA Pro9000 InkJet Photo Printer paper jam error
Had the same problem with mine. Shook it upside down and cleaned it with air cans after reading this solution for other canon printers:
http://www.fixya.com/support/t119769-false_paper_jam_warning_canon_pixma
To my surprise, it worked perfectly... and was great stress relief.
Posted on Oct 22, 2009
I have a CANON MP780. Can I print on 8.5 X 14 paper?
I believe that is the size of "legal paper". Yes you can print on that size paper. Follow this string. Go to start, all programs, Canon utilities, my printer, printer settings, locate paper size on the Main tab and select legal. This will set the printer to the wanted paper size.
Oct 02, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Can I scan legal size paper with the Canon MP 240
Hi
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
Aug 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I have a Canon MP460 & cannot print DL envelopes from a .pdf as there is a grey band showing in preview:composite. Nothing prints in this band. How do I remove it?
This appears to be a bug with the Canon software. It is not using the correct dimensions for a DL envelope.
The solution is to use a Custom Paper Size. Make it 110mm wide and 220mm high (which are the correct dimensions for a DL envelope).
To make it easy to select this size in the future, set the Custom Paper Size (plus any other options you want) and then click on the Save button. When the save dialog appears, click on Options and make sure that "Save the paper size setting" is checked. Then enter a suitable name (e.g., "Envelope DL Custom") and click OK.
Nov 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MP500 Reset PAGE SIZE to A4
Set up the parameters you want A4 Paper orientation etc then go to profiles in printing prefences and ADD to profile.. delete any others that preced this set of parameters
Please tae my help++++Thanks for using FIXYA
May 09, 2010 | Canon Pixma MP500 All-In-One InkJet...
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Epson RX650 Paper Size Default
right click the printer icon, or bring up the printer program for settings and the paper size button or tab should give you a list of paper sizes and you can set it to the a4 size for your default setting....hope it helps you...shia
May 22, 2009 | Epson Stylus RX650 All-In-One Printer
Copyer problem
Go to the Control Panel, open Printers and Faxes, right click on the icon for your Canon, choose Properties.
Since the offered settings can differ from one model to another, you may have to look at any tabs shown to find the default setting for paper type but it will probably be under 'Advanced.' Check through the various settings and you should find settings influencing which paper size the printer should use and expect.
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Scale from legal to letter
Legal size is 11x17 inches and you cannot get a legal length document when selected for landscape.
Landscape means that it is 11 inches high and 17 inches wide.
You need to set it to letter and select 11x17 inches.
May 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP810 Full Page Photo problem
Check your print settings and run an allignment check.
Sep 27, 2007 | Canon PIXMA MP810 All-In-One InkJet...
Canon PIXMA iX4000 InkJet Photo Printer Logo
18 people viewed this question
old marine
old marine
