Question about Philips Televison & Video
I need to find out part number for IC151 on phillips home theatre HTS3105/98 power supply
Power supply board number is PSU06T400M
SOURCE: phillips power supply board HJ 310432838021
http://shop.sjstv.co.uk
Posted on Oct 06, 2009
vinnyq
  • 157 Answers
SOURCE: 6 blinking red lights on my 50 inch phillips plasma.
If you see bad capicators, just replace the ones that appear to be bad. There are many different types of capicators on the power supply and there are different part number for each one. The good thing about capicators is they almost always list the ratings on the capacitor itself.
Check the Voltage rating (V) and the Farad ratings (F, usually μF), you can replace them with any one that has the same ratings. Make sure BOTH of them match the old ratings, you can purchase at just about any electronics store that carries electrical components such as RadioShack.
Posted on Oct 09, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
  • 8457 Answers
SOURCE: I have a phillips lcd
U have all the tools like a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders,also can do basic soldering and understanding of basic electronic?Yes,take out the tv power supply board,by checking it carefully ends to ends looking for dying capacitors parts,it alway bulging up on it tops or puffing up on it tops are the most common failer on the tv power supply board.By replacing all those dying capacitors,u can check the Zenith power supply board for capacitors for parts to replaced.Capacitors are very important must have the same exact micro ferit ok the voltages 5 or 10 voltages higher no problems.Take out capacitors and putting in different capacitors or new capacitors to a board must make sure polarity - + putting it in correctly to the board or will causes explosion,kill that new capacitor and more damaging to that board or the unit u tries to fix.
Posted on Feb 17, 2011
Ecollier2012
  • 3459 Answers
SOURCE: phillips tv model 47pfl5603d/f7 power
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on Jun 10, 2011
I have a samsung HT-Z310 home theatre. I left plugged and when light was restored the power ic blew. So i replaced and the power came back on but immediately it comes on it say protect.
That's the power supply board isn't it. Have you checked the main power amp board? For when the power board failed it might have taken out the main power amp with it!
Jul 25, 2016 | Samsung Audio Players & Recorders
Optic on home theatre
dry sold all ur power supply diode n capacitor mat b solved ur problem
Mar 29, 2014 | Samsung Ps-wz410 Subwoofer For Ht-z410t...
How do i connect my pc to my phillips home theatre system through an hdmi cable
The best way is to connect your laptop to a spare HDMI input on your TV first, then use the AUX OUT from your TV to the AUX IN1 of the Phillips Home theatre system using a standard RCA cable.
The only catch with this is that you will have stereo analog audio, NOT digital surround. However, by pressing the "SURROUND" button of your Phillips HTS remote you can switch the audio output to multi-channel surround, stereo or party mode.
What is the model number of the TV you are using?
Oct 23, 2012 | Philips HTS-3565 Theater System
My lg tv as optical audio out but my phillips surround system dont have any optical audio how can i connect tv audio to my home theatre speakers
Observe the back of your tv and look for audio out it is commonly colored white and red use a rca jack and connect it to your theatre speaker audio in also located at the back of your home theatre, hope this help good day and best regards.
Sep 14, 2011 | Televison & Video
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
May 13, 2009 | Sony DAV-HDX500 System
I have a 52" projection tv it is a phillips. one day i came home and i went to turn it on. now what do i do it wont turn on?
In the absence of any warnings of impending failure, the main power supply has probably failed.
This is likely to be a separate assembly (board) that you could replace on your own. If you remove the back lower panel, follow the AC cord to locate the supply, get the part number from the assembly (there may be two different numbers). The bare circuit board may have a number that was printed in the same manner as the component identifiers and then another number on a label which might contain a 'revision' number too. This board is probably not terribly tought to repair with the necessary instruments but you would be better off buying a new board and then looking for someone to repair the other since it will probably be needed when the replacement fails.
Feb 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
Dell w4201chd 42" Plasma Tv.
OK, you need to replace the Power Supply Board.It is made by Samsung the number on the board will be LJ44-00110A. The Replacement number is LJ44-00019A,the cost is $349.00,however this part also crosses to a Phillips number 99500042146 which sells for $289.00 these are all the same board.I use the Phillips Board.Most repair shops will not do any research to locate these boards due to time and volume of repairs the have to deal with.Most call Dell and they won't give out repair info.They require it to be sent in.The Phillips board can be purchased from any NAP distributor.
Feb 11, 2009 | Dell W4201C 42 in. Plasma HDTV
I bought philips 5.1 home theatre for PC it is not supporting
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jul 02, 2008 | Philips HTS3450 System
Phillips LX3600 Home Theatre
Power up the set and open tray in DVD mode.
Press <9999> follow by <X> buttons on the Remote control.
where x = numeric 1 to 6 denoting the regions below:
Then show your region on TV
1 = USA
2 = Europe
3 = Asia Pacific
4 = Australia, New Zealand, Latam
5 = Russia, India
6 = China
0 = Code Free
This is taken from the original service manual for the reciever
Jan 27, 2008 | Philips LX3600D System
Phillips webcam model SIC 4750/27
i need the same thing, i lost the cd and now i cant use the camera. what do i do? it is a philips sic4750/27
Jan 05, 2008 | Philips J44414
Televison & Video Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
