Question about Goodman CKL60AR60 Air Conditioner
What size capacitor for a cpke42-1b
Working on it no capacitor on unit
    Master:
  • 359 Answers
You will need to call Goodman. I rely can't imaggin how the compressor can start with out a start run capacitor.
Posted on May 15, 2014
Trying to determine what size capacitor my unit C1048BBD1VF uses for my AC unit. Is it larger then a 45 amp? Replace it with a 45 and you can hear it try to turn on but it won't.
capacitors are rated in microfarads or picofarads and not amps
capacitors are used to provide a boost voltage to start motors and then to keep them running
Amps is current flow so what ever you replaced was the wrong unit.
on the side of a capacitor will be voltage rating (110-115-220-240 etc and a number 45 -55 60 uf etc
it will have either 2 terminals or 4 terminals connected as pairs
from what you describe it is a capacitor problem
May 26, 2016 | Airwell Fedders Fedders C1048bbd3vf 3...
Blower fan inside unit doesn't work no capacitor in this unit
are you sure of that
the capacitor is about the size of a cap of a highlighter pen
( about 3/4" by 1/4" by 3/4") and is probably on the power board
best get in a service technician to check out the board
Nov 20, 2015 | Heating & Cooling
I HAVE 1.5 TON SPLIT A/C WHAT SIZE OF RUNNING CAPACITOR WILL WORK IN COMPRESSOR?
the capacitor that is required is the same size as what is fitted
it will read as voltage and uf number
best have a ac technician check it out as it may not be the capacitor but the power board
some ac units have a capacitor that is in effect two capacitors in one to run the compressor and the cooling fan as well
best get the technician in as it could save a lot of money in the long run
Aug 08, 2015 | Dayton Permanent Split Capacitor Motor Fan
Common size capacitor for 2 ton units
if you are looking to buy capacitors to make money,the only way to make money is by repairing the units,if you are doing that,then you dont need to ask what size,you would know
May 17, 2015 | Heating & Cooling
What size capacitor do i need for a 2.5 ton compressor
Each brand of unit uses different sized capacitors I need a model and serial number of your unit to actually cross reference that part. You could also call the manufacturer of you unit and find out.
Aug 26, 2014 | Heating & Cooling
I have a intertherm e2eb-012ha. I need to know what size run cap to use. . The plastic coating has been melted so I can not see the run cap info.
It appears you may already have located your problem, the capacitors are very coming to burn out, if a motor will run after you spin by hand, mmore times than not the capacitor is the problem. The name tag on the equipment itself sometimes has the capacitor size and the motor nameplate usually does as well. you can call Nordyne support at 18004224328 and with your Intertherm Model number they can give you the correct capacitor size, which you can purchase at any HVAC supply house. If I had to guess, I would say you need a 5 mfd capacitor based on the blower size. but call them and verify. Also, most all supply houses that sell that capacitor can run the Intertherm numbers and see the correct size as well.
Jan 06, 2013 | Heating & Cooling
Unit needs a new capacitor and it does not the value printed on it and its not on the label
Short of going direct to the manufacturer and getting the genuine part off them using the model number, it would be very difficult. Compressor size and machine size very often have no bearing on what capacitance the capacitor has... Have a very close look at the capacitor for a uf rating.. this is the value you need. sometimes, it is listed on the wiring diagram which is usually behind the panel which covers the main wiring terminal box on the outdoor unit.
Aug 04, 2011 | Ruud UAKA060 Air Conditioner
I just bought a new compressor for my a/c but the store sold me the wrong capacitor. I need a dual capacitor but don't know how to read microferets to get the correct capacitor. Can you help me?
Do you still have the original capacitor for the unit. They probably gave you the size you need for the compressor. It should have the microfarads printed on the capacitor. The symbol resembles a strange looking u. Then look at the capacitor that came with the unit and get the microfarad rating for the fan. Now you will have the too readings you need to get a capacitor. The fan motor may also have the size capacitor you need printed on the data plate. Let me know if you need more help.
Jul 03, 2010 | Heating & Cooling
Need Capacitor Size
try calling technical support of the company
Jun 04, 2009 | Intertherm P3RA-030K Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
70 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
